Old 08-13-2005, 04:18 PM   #1
Year: 1968
Engine: Chevy 350 (1980)
Transmission and tire questions
I recently completed my maiden voyage and shakedown cruise on my '69 Chevy skoolie with an '80 350 V8. Aside from a couple of small problems (ie flat tire and bad coil) which popped up, it was quite fun!
Of course now that things are shaken down, i have a couple of questions...
First: I've got a 5 speed manual, and the syncros are going. I can double-clutch no problem, but sooner or later, i'll need to either rebuild or replace. If I replace, is it possible to get a tranny (used of course) with a better gear ratio? If this is possible what would be a good ratio to increase highway speeds? Don't know what mine is, but i'm not getting real good highway speeds, about 55mph. Could go faster, but the RPMs are pretty high already.
And second: My tires. I've read the chock-full-of-info Wheel FAQ, but i just gotta get this clear. I've got 9R20s (tube tires) on split rims. Tires need to be replaced. Can I upgrade to tubeless tires on the same rims? If so would i be looking for a 10.5R22.5?
Many thanks,
Steve
deschste is offline   Reply With Quote
Old 08-14-2005, 05:07 AM   #2
Roasting8's Avatar
Year: 1981
Chassis: Crown
Engine: 671 DD
Send a message via MSN to Roasting8 Send a message via Yahoo to Roasting8
Welcome Steve,
The only way that you're going to change the top end on your bus is by either getting an overdrive transmission or changing the gear in your rear axle. Most likely your axle has the ratio stamped on it and you would have to go from a higher number to a lower number (example: 4.65 to 3.90). The thing you've got to watch out for is that you'll lose pulling power and you'll feel it when you're climbing hills, but if your bus has enough power, that you can live with, you should be able to do it.
As for the tires; you're going to have to change rims if you're going for 22.5 tubeless tires.
Roasting8 is offline   Reply With Quote
Old 08-16-2005, 08:55 PM   #3
Coachwork: Ward Genesis
Engine: DT466/MT643
A 10R22.5 is the same height (+/- an inch) as a 9.00-20. However, that reqwuires 6 new wheels...pricey. I'd get 9.00R20 tube radials--probably either new tires or good take-offs in front, and take-offs or Bandag retreads in back.
Jarlaxle
Old 08-20-2005, 12:41 PM   #4
Year: 1968
Thank you for the tips gentlemen! I guess i'll go look for some new tires and just get used to double-clutching for a while. With my 350 engine already feeling a bit weak, I guess I shouldn't go changing the gear ratio right now. Maybe when I get a new engine! (Hah!)
Steve
RV tire blowout wmkbailey Everything Else | General Skoolie Discussions 0 09-04-2013 10:28 AM
Engine and Transmission Questions - looking at two busses bansil Mechanical and Drivetrains 19 07-29-2013 09:39 PM
Tire Pressure? TygerCub Conversion General Discussions 20 07-19-2012 08:11 PM
Tire Protection? hoser Everything Else | General Skoolie Discussions 4 07-04-2008 12:22 AM
Tire Thumping. What is it and should I do it? busone Conversion General Discussions 5 10-12-2005 04:52 AM
