Old 05-08-2008, 07:02 PM   #11
Les Lampman's Avatar
Re: Transmission supports on 1988 thomas safe t liner
Originally Posted by Thomps
If you get a chance please look it would be very much appreciated. thanks
Hiya! I just got home (I'm on the west coast). I took a look at my bus today and the transmission definitely just hangs there off the engine with no other visible means of support.
Les Lampman
1982 Thomas Saf-T-Liner Pusher "Illusion"
Skoolie.net Gallery
Illusion's SmugMug site
Les Lampman is offline   Reply With Quote
Old 05-12-2008, 10:54 PM   #12
Chassis: Thomas
Engine: 8.3
Well its nice to know my bus is not alone.
Have any of you guys had to deal with rusted out acid eaten battery compartments? Mine has a fair bit af damage battery try has rust holes in it and the battery tray roller slides are rusted solid and the tray wont pull out. Any good ideas on how to fix it? Also have a leaking front heater core. Are the front and rear cores the same because i dont think iam going to keep the cabin heaters in the rear
Thomps is offline   Reply With Quote
2000 Thomas Saf-t Liner steve.c Skoolie Conversion Projects 52 10-29-2014 04:26 PM
1989 Thomas Saf-T-Liner GoneCamping Classifieds | Buy, Sell, Swap 0 01-09-2009 09:05 PM
1982 Thomas Safe-T-Liner "Illusion" Les Lampman Skoolie Conversion Projects 89 02-28-2007 07:41 AM
82 Thomas Saf-T-Liner Transmission Slippage w1bmw Skoolie Conversion Projects 13 09-20-2006 05:26 PM
89 Thomas Saf-T-liner Skoolie.... GoneCamping Skoolie Conversion Projects 2 09-08-2006 09:28 PM
