Old 12-31-2015, 01:43 PM   #1
transmission wisdom
ok fellow skoolies, i'm looking for some future advice.
i predict that my transmission will fail (at 545). it makes noise, it slips on grades, it makes me worry
plus i like to tow with it
it is paired to cummins 5.9 12v in a flat front FE bluebird.
so, if the trans fails..... do i rebuild it?
do i find a donor bus and swap the 545?
do i find a donor bus with a md3060?
do i find a donor bus with a FE 8.3 cummmins and transmission combo? would that fit?
are there other options?
might be easier to move the conversion onto a new bus instead of a repower.
whats the cheapest/best fix on something this major?
Turfmobile Build Thread
Old 12-31-2015, 01:51 PM   #2
crazycal's Avatar
You can buy a rebuilt AT545 for about $1800. That is the simplest option. I have also seen used 545s on craigslist for as cheap as a few hundred. Someone here had one here that the offered for free.
I'm hungry!
You Gotta Let Me Fly
Old 12-31-2015, 02:13 PM   #3
Scooternj's Avatar
Chassis: International 3000RE
Engine: T444E/AT545
Rated Cap: 75
Swap it with an MD3060
Captain Obvious on deviantArt
Old 12-31-2015, 03:01 PM   #4
opus's Avatar
Chassis: All-American R/E
Tango had one he was giving away.
Old 12-31-2015, 04:00 PM   #5
Alan N's Avatar
Year: 1975
Chassis: Gillig
I have an 545.
Free for bus people.
Alan N is offline   Reply With Quote
Old 12-31-2015, 05:15 PM   #6
Me too. Free to any Skoolie who needs it. In Houston Texas.
Old 12-31-2015, 06:17 PM   #7
crazycal's Avatar
A swap is fine but not a simple task if you don't have the skills. The MD3060 requires a computer. The shifter alone is 500-1000, so is the ECU. If money is no object, go for it.
I'm hungry!
Old 12-31-2015, 06:25 PM   #8
And if you have ten-grand...the new gen Allison six speeds have double OD and don't need a computer. Just a TPS (Throttle Position Sensor).
Old 12-31-2015, 07:17 PM   #9
crazycal's Avatar
Sure, I'll take 2 please.
I'm hungry!
Old 01-01-2016, 09:34 AM   #10
2 ?!?!?! good grief
didnt i ask for cheapest / best?
at 10k, i think, i could transplant the bigger cummins plus trans.
i think the simplest answer is probably the cheapest..... swaping a used 545 in.
therefore, im interested in either of those 545's. googling your locations im half way in between both of you.....from colorado its a 1000 miles either way.
does the fact that one came from a cat motor change the bell? any ideas on the mileage on those trans?
thanks for all the help!!!
