09-24-2017, 02:24 PM
Trap door over the engine in a re?
I have tried to google this question but keep getting pointed to battery doors, side engine doors, etc. In a RE school, is there a door right over the engine compartment, leading into the interior, so that some forms of engine repair and maintenance can be done more easily?
09-24-2017, 02:56 PM
Chassis: Bluebird
Engine: 5.9 Cummins 24v
Rated Cap: 72 pax
On my 2002 all American there is a rear panel that can bolt off if you need access. I would say that unless you are removing the engine, it isn't likely I would have to open this panel. I have the 5.9, and can reach just about everything on the engine from the rear door.
09-24-2017, 03:41 PM
Chassis: HDX
Engine: Cat C7
Rated Cap: 84 passenger
No, usually not. All of my engine access is from the rear, a very large door. If I try to access it from the inside, the doghouse is large and a very large number of screws hold it down.
09-24-2017, 04:39 PM
I also have the 2002 All American RE. I have the 8.3 Cummins and will leave the access panel accessable. The 8.3 is a bit longer and taller than the 5.9 making the top access more important.
09-24-2017, 04:44 PM
Coachwork: New Flyer
Chassis: D45HF "Viking"
Rated Cap: 51,600
In an RE, a trap door from the engine compartment to the inside would be too much of a fire hazard. If a fire started in the engine compartment, it has a much easier time moving into the passenger compartment through the space between the mounting and the trap door.
Or, the trap door costs as much as the bus to make it fire resistant enough to give the driver and occupants time to stop the bus and get out....
09-24-2017, 04:52 PM
Most RE buses come from the factory with access panels that allow access to the top front (or rear depending on how you are looking at it) of the engine from inside the bus.
It does not appear to have been a problem so far.
09-24-2017, 04:55 PM
Chassis: Bluebird
Rated Cap: 72 pax
My rear panel is a heck of a lot more solid than any fe doghouse I have ever seen. It's solid and was a 4 person seat. It has screws holding it in, and it can be removed. As Steve notes, different engine configurations may make it necessary to go in from that angle.
09-24-2017, 07:22 PM
Rated Cap: 51,600
Well, I stand corrected then. I've not seen an RE with such a hatch, but I probably wouldn't buy such a bus just from that standpoint.
09-24-2017, 08:25 PM
Year: 98
yes , we have one in our RE, very handy for some stuff.
Later J
09-24-2017, 08:36 PM
Chassis: Bluebird
Rated Cap: 72 pax
It isn't like a dog house, it's an access panel. Screwed down. Most are Incorporated into the rear bench seat.
09-24-2017, 11:07 PM
Rated Cap: 37,400 lbs GVWR
I have a hatch under my rear seat that gives me easy access to the rear of the engine where the hydraulic/PS pump and air compressor are. I can also reach the end of the blower and the turbo through there, and with some contortions and a crowfoot wrench I can also reach the transmission temperature gauge's sender through it. Without this hatch they would be inaccessible. (I'm thinking about installing a bypass valve on the blower to gain a few HP, and it will be easy to reach that area through the hatch.) If any RE bus does not have easy access to the back of the engine, you will have a problem when (not if) you need to get back there.
Likewise, if a bus has floor hatches above the engine and transmission (like mid-engine Crowns and Gilligs) or above the fuel tank, leave them accessible! Covering them over is asking for trouble.
09-25-2017, 07:17 AM
Year: 1972
Engine: 366 BBC
In my 72 All American there is a hatch... Honestly, doubt you will ever need it... the bus is extremely accessible from the outside the way the corners swing open.. But I still didn't cover it, just in case
Living the dream in the Swag Pad!
09-30-2017, 12:45 AM
That's an escape hatch for the hamsters. LoL look into it see what's there or it could be a fresh air intake and the grate/ cover is missing . mine is a 92 TC2000 and air intake is on right top rear of body and has a lift up door on the engine compartment
Sent from my LGL64VL using Tapatalk
09-30-2017, 11:05 AM
Chassis: AARE
Engine: 3116 Cat 250hp
91 AARE has a hatch, I did open it up to get a proper reading on the gauge when I adjusted the valves. If you have a hatch don't build over it without some means of getting it open. It's there for a reason.
