Old 10-23-2019, 11:15 PM   #1
Truck body on Bus?
I found an international 42-43-4400 crew cab body for sale and was wondering if theres any way it could be mounted to a mid length bus frame if the bus body were removed. I'd just make whatever whas left of the frame into a flatbed as a work vehicle.
Ripper06 is offline   Reply With Quote
Old 10-23-2019, 11:49 PM   #2
Anything is possible with an angle grinder and a welder.
Take some measurements from both and go from there.
o1marc is online now   Reply With Quote
Old 10-24-2019, 12:31 AM   #3
Chassis: IH
Should be relatively straightforward if you find an IH bus, the frames were similar and much of the electricals and mechanicals should interchange easily enough. The hoods *may* be different (or they may be the same) but from the cowl back the bodywork will be different (obviously, to accommodate the bus bodywork).
Old 10-24-2019, 12:40 AM   #4
That sounds like a great project
