Old 05-31-2012, 04:20 PM   #1
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
turn signal gasket
I have a couple of turnsignal/marker lights that are in quite nice shape, but the rubber gasket is gone. Bluebird no longer stocks it, they want to replace whole assy at over $90 a pop,made by some other company. The old gasket is a u shaped deal that goes around the socket assy and is the seal for both the assy and the lens. It's made by a German company, R & S. I've not hand any luck with any searches. Anyone have any suggestions on how to make or find something suitable? I've included some pics including numbers stamped on back and a detail of the gasket.
It's a 91 Rear Engine All American, the location of the light is on the front,outside of headlight on the curved panel.
Thanks in advance.
Old 05-31-2012, 04:33 PM   #2
Re: turn signal gasket
Check out Rogers Corporation
http://www.rogerscorp.com
Look at the PORON product
4701-40-15250-04 (6.35mm)
4701-40-15375-04 (9.53mm)
this is a dense foam that comes in sheets sample size (8.5x11 you pay shipping
Might work if you trace it out and then glue to one side
Old 05-31-2012, 09:31 PM   #3
lornaschinske's Avatar
Rated Cap: 89
I used craft foam (thin sheets of coloured foam) that I bought from Wal-Mart. comes in 4X6 & 8X11 (possibly slightly larger). I remade all my gaskets from the stuff. I used a paper hole punch to punch out the holes for the screws. A dot of silicone or EU6000 held the gasket in place while I put everything together. That way I didn't have to worry the gasket was slightly out of place (a coomon problem with my old gaskets.. it let dirt & water in).
Fulltime since 2006
Old 06-01-2012, 09:28 AM   #4
i use dense foam like the prev mentioned, and heat for shaping under a form.
Old 06-01-2012, 06:44 PM   #5
browncrown's Avatar
Rated Cap: 79 at Birth
All of my gaskets are flat sided and I use the method described by Lorna. Seems like the thicker foam posted by Bansil would work well for more rounded coverings.
BC
My Conversion Thread: https://www.skoolie.net/forum/viewtopic.php?f=9&t=3065
Old 06-02-2012, 01:43 AM   #6
one can also buy bulk foam with one side a stick on peelable film. its in automotive paint stores, and probably parts stores.. its made just for this kind of repair.
looking for 4 way flasher/turn signal relay syke Conversion General Discussions 13 05-24-2012 12:40 PM
Blue Bird turn signal failure? Huey Everything Else | General Skoolie Discussions 2 10-08-2008 03:07 PM
HEAD GASKET FAILURES NEW FORD 6.0 mike Everything Else | General Skoolie Discussions 3 09-11-2006 07:20 AM
Rubber window seal/gasket w1bmw Classifieds | Buy, Sell, Swap 2 08-16-2006 02:58 PM
Stop Signal Removal- need help fast Jody Conversion General Discussions 2 06-08-2006 11:23 PM
