Originally Posted by gmrubin
What is the collective's opinion of a two way valve on the shower drain. Set one way the shower would drain into the gray tank, set the other way it would drain to the ground. Most of my boondocking is in the desert southwest and shower water seems a lot cleaner then normal gray water.
I will have a composting toilet so I may be dumping the pee bottle into the gray tank at times. I wouldn't consider dumping that. I'm planning 100 gallons fresh and a 50 gallon gray tank and would like to go up to 2 weeks without dumping. I can periodically refill the fresh tank with my four 5 gallon water jugs.
It's never a good idea to simply dump grey water on the ground. It's not meant to be in the desert, so try to take it away with you.
Leave only footprints (and tire tracks) and take only memories.
In forested areas it's perfectly fine to pour grey water under hedges and inside thick shrubs. They will use the water and the small amount of contaminants will not hurt areas with thick growth.
