Old 04-24-2011, 06:56 AM   #1
Ob1
Year: 1963
Coachwork: Grumman
Chassis: Chevrolet
Engine: Chevy 292 I-6
Re: Unique (perhaps) power setup?
It only exceeds the generator breaker if you use the full capacity of each sub breaker. Do you know the amperage draw of your AC unit? Sounds like your other 120VAC needs are fairly small.
Amps = Watts divided by Volts
Convert each appliance to amps and add them up, per circuit. Compare to your sub breaker ratings. You might want to leave some capacity to spare, the starting load of the A/C compressor draws more power.
You can also just test the circuit in action and find out what it will really do. Fire off the A/C, then start turning on other appliances until a breaker fails. Know your maximum load in reality, and simply stay below it!
Ob1 is offline   Reply With Quote
Old 04-24-2011, 03:45 PM   #2
Ob1
Year: 1963
Coachwork: Grumman
Chassis: Chevrolet
6.4KW is probably it's surge rating, like when the A/C first starts up {and to a degree every time the compressor kicks back in}
Old 04-24-2011, 05:39 PM   #3
lornaschinske's Avatar
Rated Cap: 89
You should have no problem running the air plus a few other things.
Fulltime since 2006
Repower setup Taystools Mechanical and Drivetrains 26 02-05-2014 06:47 PM
Great website for unique and hard to find wiring products crazycal Conversion Tutorials and How-to's 2 06-04-2013 06:38 AM
How wild is your A/V setup? NewSkewlHauler Conversion General Discussions 16 07-06-2010 01:13 PM
My new solar setup Steve Everything Else | General Skoolie Discussions 18 09-09-2007 11:20 PM
Unique Taos Artisian Craftsman Rolling Home ~ Bus For Sale Taos Bus Classifieds | Buy, Sell, Swap 0 03-24-2007 03:03 PM
