Old 10-16-2017, 11:40 AM   #1
Engine: dt466e
Upholstered walls in front of bus seats
Did any of you keep them for any reason? Just got done removing my bus seats and trying to decide on whether or not to keep them. Im referring to the little walls in the very front, one on each side that have the same leather material as the bus seats
adic27 is offline   Reply With Quote
Old 10-16-2017, 12:02 PM   #2
Njsurf73's Avatar
Chassis: Bluebird
Engine: 5.9 Cummins 24v
Rated Cap: 72 pax
They are there as part of the safety system. In the event of a crash, the child seated in the front row hits the wall instead of the windshield. They also keep you from falling down the entry steps!. No real reason to keep them unless you have a seat behind them.
Old 10-16-2017, 03:11 PM   #3
I have fallen down my bus bus steps twice since I took those out...I though that I was just a klutz....
I am going to put a co-pilot seat there. It had to go.
Old 10-16-2017, 09:33 PM   #4
I was thinking of cutting the passengers side down around 6 inches or so so I could keep the grab rail and put a screen on the bottom so items don't keep falling into the well while driving. Passengers "should" be able to see out at that level.
Behind the driver I'm putting a cabinet and counter so will leave it in place.
2002 E450 Thomas/ U-JOINT 4X4, family hauler
1954 Crown 35 foot RV conversion, guest house
1945? City Bus (unknown manufacture), yard art
1940s 'Binder 7 window, man cave
Oldcarnut is offline   Reply With Quote
Old 10-16-2017, 11:38 PM   #5
Engine: dt466e
Something was telling me to keep them but i threw them out anyways
Old 10-17-2017, 09:04 AM   #6
Dead pirate's Avatar
Coachwork: myself
Chassis: amtran
Engine: international dt466e allison md 3060
Rated Cap: 13 ton or so says the tit
This is what i have done. Cut the passenger side down to keep the rail.
Sent from my LG-LS777 using Tapatalk
Dead pirate is offline   Reply With Quote
Old 12-10-2017, 04:14 PM   #7
golfersmurf57's Avatar
I removed both of mine going to add a finished wooden banister to help with entry stairs. Drivers side will.use for toolbox placement close to steps for access. Or may mount Heater removed from floorboard for drivers comfort.
Sent from my LGL64VL using Tapatalk
golfersmurf57 is offline   Reply With Quote
