Old 01-21-2005, 06:31 PM   #11
well I went by and picked up that ups..specs are: SL Waber Powerhouse 250
250VA back-up power supply....max output current is 12 amps..it h as four plug ins with two being on the back-up and two as surge protected only. Only has a single 12V, 4Ah batt in it though (ok, I was hopeing for two but it did feel light)..I'll plug it in a see if the batt chares at all..the case has been broken (of 4 screws holding it together only one does), so that may be the only thing wrong with it.
Demonknight is offline   Reply With Quote
Old 01-27-2005, 10:08 PM   #12
I plan on doing the "UPS-as-Inverter" fairly soon.
(i've 3-4 ups's laying around)
I've already used a "car battery" with one.. increasing my 6 minutes of runtime to almost 1 hour of active computer use.
I do want to take advantage of the auto-transfer switch capability.
but i also worry about the charging.
I do plan to run the ups off of my house bank, and will be getting rid of my current converter for a (ghetto) 3-stage charger.
I cannot see how the UPS could be quick and/or efficient in charging a large bank (well someday a large one). and I'm worried that it's "trickle charge" will confuse my other charger into either shutting off or at the least going into float mode too early with a false recharged signal..
I've contacted APC's tech support.. they were happy to help.. but said help boiled down to "unplug it" D'oh!
I wont be doing this mod until spring, but i'll post what i learn, and wil check back for more from you guys
robert
koldei is offline   Reply With Quote
Old 04-18-2005, 02:54 PM   #13
trx
trx's Avatar
Chassis: Chevy C-60
Engine: 8.2L Turbo Detroit Diesel
Send a message via ICQ to trx
Has anyone found and documentation on the efficiency of UPS inverters? I have a large server UPS that seemed like a good idea at first to use as an inverter but that was a bust because it didn't support cold starts (starting up off batteries). Glad it was free. I also wondered how much extra power it used on communications & monitoring? The one I have looks like this. Since they are typically used only long enough to shut down your computer then I wonder if they try to make them efficient. No load draw could also be high. The one I have uses a large transformer which I suspect could hurt efficiency.
Chad
trx is offline   Reply With Quote
Old 04-19-2005, 07:43 AM   #14
trx
trx's Avatar
Chassis: Chevy C-60
Yeah, we verified with the manufacturer that it does not support cold starts. Anyone want to buy a nice UPS? I did gain a couple nice batteries for my riding lawn mower.
1 inverter and 3 outlets ThePimentals Electrical, Charging and Solar 17 09-25-2014 07:26 AM
Inverter FAQ's lornaschinske Conversion Tutorials and How-to's 4 08-13-2012 08:15 PM
new inverter/generator gbstewart Conversion General Discussions 3 12-17-2010 01:42 PM
What Inverter To Get? lapeer20m Conversion General Discussions 1 05-14-2010 12:31 PM
Why use an inverter? lapeer20m Conversion General Discussions 5 09-07-2008 05:01 PM
