Old 05-21-2015, 07:59 PM   #1
Urgent: Brake Light Wiring
Hey Everyone,
So tomorrow we are supposed to be leaving on our adventure but we have run into a small issue.
Our brake lights are working fine. However, when we put on our headlights, we don't have any lights that come on on the back of the bus. The bulbs for our brake lights have two filaments in them. One we think is for the braking (and works) and the other is for 'running' lights (Doesn't work).
Our bus is a 95 Carpenter school bus.
Any suggestions? I know it could be a million things but if you could think of the first few, that would be great!
03dunner is offline   Reply With Quote
Old 05-21-2015, 08:04 PM   #2
try and replace the bulb, maybe it is the problem, or the socket is corroded
c_hasbeen is offline   Reply With Quote
Old 05-21-2015, 08:31 PM   #3
As a quick fix, assuming you do have front parking lamps that work--and clearance lights that work, snip the tail lamp wire and run a new wire to either of the working lamps and call it good. If none of the parking lamps work and the clearance lamps don't work, it may just be a blown fuse which probably means a short somewhere though not necessarily. Good luck!
Old 05-21-2015, 10:27 PM   #4
Are the brake lights dim?
Do the brake lights work when the parking lights are on?
It could be a bad ground. You usually see this with a trailer having a rusty connection to the tow vehicle, but it could happen elsewhere. Usually, in that case the taillights OR the brake lights work, but not together.
With the taillights off and a bad ground, the power from the brake lamp filament in the bulb continues into the parking light filament, and then goes to ground through other parking light bulbs elsewhere in the vehicle. The taillights would work in the opposite direction. Since the brake light is normally brighter, it has a lower resistance in order to draw more current. So the parking lights would ground through two low resistance brake light filaments in series and be reasonably bright. When you step on the brakes, the junction between the two brake lights goes hot and the taillights lose their ground path. With both filaments hot at the ungrounded socket, both the brake and taillight will go out until one or the other is turned off to establish a ground path again.
So with a the brake lights instead of the taillights, they would ground (dimly) through a higher resistance in the same bulb, but then all the turned off parking and possibly also marker lights would be in parallel going to ground and lower the resistance to that part of the series-parallel network.
As I said, if it is a bad ground to the socket, the brake lights should stop working when the taillights are turned on. If not, look at the bulb and the other wiring fixes.
P.S. The buttons on the bulbs are generally blobs of lead-based solder, and they will get a high-resistance powdery tarnish on the surfaces with age. I have brought many a "dead" bulb back to life by vigorously rubbing the buttons on my jeans to polish them until they are shiny again.
