Old 12-23-2017, 11:37 AM   #1
Year: 2006
Chassis: IC bus
Engine: VT365
Rated Cap: 35C24A
use screws to patch old bolt/screw holes
I know it must be somewhere on the forum but I couldn't find it...
What is the general consensus on using screws to patch the bolt and floor screw holes and then grinding them down just above the end of the heads.
Seems like an easy fix but I haven't noticed any mention of it. Is there an obvious reason that I am not seeing?
Tyania is offline   Reply With Quote
Old 12-23-2017, 11:46 AM   #2
Chassis: Saf-T-Liner MVP ER
Well ECCB would tell you to use JB Weld ..
I'm leaving the plywood down so on this one occasion I'll squirt silicone sealant.
One good solution is simply to epoxy pennies over the holes.
Some weld patches over the larger holes, and weld shut the small ones
I'd avoid anything that requires yet more grinding.
Steve Bracken
Build Thread
Old 12-23-2017, 12:02 PM   #3
Defjr333's Avatar
Chassis: Step Van
Engine: Prefer Diesel
Rated Cap: 14'-16' Step Van
And the JB Weld jokes keep rolling in. Its like Franks Red Hot...he puts that sh1t on everything......Poor ECCB.
Id almost start a thread of just JB Weld jokes for him!
Doug
Ebike Build Thread: https://electricbike.com/forum/forum...need-your-help
StepVan Build Thread: Coming Soon
Defjr333 is offline   Reply With Quote
Old 12-23-2017, 02:18 PM   #4
wunderhut's Avatar
Chassis: AARE 3903
Engine: Cummins 6CTA 8.3
I just primer the bare metal on the holes and put a piece of butyl mastic foil tape over the hole. It's totally flat so easy to build over and it's waterproof.
wunderhut is offline   Reply With Quote
Old 12-23-2017, 06:42 PM   #5
Robin97396's Avatar
On my first bus, and without knowing about this site, I used BlackJack roof repair to coat the steel subfloor on a badly rusted floor. It didn't stink like tar, even in summer and the floor is still good. As for all the screw and bolt holes the underside of the floor looks like it has black worms hanging from the floor.
Robin
Nobody's Business
