Old 12-20-2007, 02:20 PM   #1
Chassis: All American RE
Engine: Cummins 8.3
Using a different style windshield?
Hi:
I was wondering if there were anyone that had considered putting a different (taller) windshield on their bus.
My glass are both scratched and I plan to raise the roof, so I was wondering if it would be feasible to locate a taller windshield and put that on instead of just replacing the glass that's there now. If it's possible, it should be done early with the body work. Otherwise, I'll look into replacing/fixing the current glass later in the process.
thx - Tony
dentarthurdent is offline   Reply With Quote
Old 12-20-2007, 02:58 PM   #2
Steve's Avatar
Re: Using a different style windshield?
It is not practical if your windshield is curved. Windscreens are made of safety glass and any glass shop will be able to cut it into any shape you want, as long as it is flat.
Old 12-20-2007, 06:20 PM   #3
reprobate's Avatar
I just raised my roof 18" and considered a little more glass or a window, but the weather nixed both. One thing you should consider is when you add more glass you might want to dark tint the upper or you could really take a beating from the sun. Best of luck.
reprobate is offline   Reply With Quote
Old 12-20-2007, 10:48 PM   #4
Moderator
crazycal's Avatar
Engine: DT408, AT545
Rated Cap: 23 500 gvw
I think windshields are laminated. All the others are safety glass.
I'm hungry!
You Gotta Let Me Fly
Old 12-21-2007, 05:08 PM   #5
lapeer20m's Avatar
the bus i just sold had laminated glass in all the windows. if you've ever "cracked" one of the windows in your skoolie and it didn't get much worse then it's laminated glass. If you put a small "crack" anywhere in tempered glass the entire window will either shatter immediately or fall apart the next time you drive.
i don't know how other buses are put together. This was on a thomas body.
Old 12-21-2007, 06:44 PM   #6
Moderator
crazycal's Avatar
I don't know if you can see the window by the left side door, but it was broken when I bought it and it's in a million pieces. That bus is a Ward. I think laminated is more expensive than safety.
I'm hungry!
Need 63 Windshield Tweety Classifieds | Buy, Sell, Swap 2 11-01-2010 04:17 PM
What style of Rivits are you using on your skoolies Gyva Conversion General Discussions 1 02-16-2010 09:04 PM
Chicago Style Politics? Abbott Everything Else | General Skoolie Discussions 0 12-17-2009 10:33 AM
roof raise style adamanderr Conversion General Discussions 2 10-22-2009 12:12 PM
Home Style Appliances fankhaj1 Heating, Cooling and Appliances 11 11-26-2005 01:54 PM
