Old 11-23-2008, 08:39 PM   #1
Lady Franklin's Avatar
Engine: 7.3 International Diesel
Re: Using seat foam for insulation??
Won't say you couldn't but R value would be hard to peg down but I would guess it at about 2-5 an inch. These seats are treated for fire to make them fire retardent but I don't know when the manufacturers started to do this. Would make for a ton of cutting and fitting though. I would make sure you have a very non-permeable building envelope though because if you get water in that stuff I think you will find it will mould. Might be good to do some R-value testing with it. I made some cushions some time ago and cut the foam with a band saw which worked decent unitl too much foam got on the drive belt and burned it out, so beware.
Lady Franklin is offline   Reply With Quote
Old 12-04-2008, 05:52 PM   #2
KevinCoughlin's Avatar
Year: 1983
Chassis: International S1800
Engine: SV396 V-8, International
Send a message via Yahoo to KevinCoughlin
I have heard that using an electric turkey knife is good for foam. I use just a basic (but freshly sharpened) chef's knife to cut foam.
I use the styrofoam board for the walls, though. They won't absorb moisture like the open cell foam in the seats will.
Check out the Millenium Phoenix
<www>
KevinCoughlin is offline   Reply With Quote
Old 12-10-2008, 01:06 PM   #3
TikiBus's Avatar
Year: 92
Coachwork: Amtran Genesis
Engine: International DT466
I was considering doing the same for the ceiling, but mounting part of the pad and the pleather to a plywood base ( 2'x3'?)and attaching it to the ceiling, creating a pleated look. Hopefully it would provide some insulation because Ive got the cieling of ten-thousand holes, releasing my heat to the sky. I've seen someone's front ceiling done this way on here. For the floor, your best bet might be the closed cell board, Its a heck of a lot easier and less time consuming x10. Has anyone thought of other uses (or actually used) for the padding. If so, let us know! What other applications CAN the seat foam be used for?
TikiBus is offline   Reply With Quote
Expanding foam insulation PDBreske Conversion Tutorials and How-to's 10 02-25-2014 08:31 PM
Insulation Board: Polyiso or Foam? Westward Conversion General Discussions 5 09-27-2013 11:27 AM
Looking for plush seat cuchion foam putterspitt Conversion General Discussions 2 02-02-2011 03:04 PM
Bus seat foam BUSBOZO Conversion General Discussions 7 01-17-2010 10:11 PM
foam vs batting wall insulation adamanderr Conversion General Discussions 1 10-19-2008 10:07 PM
