Currently my bus is gutted and I'm trying to do some wiring, etc before include stuff in. So I bought some LED spotlights I'd like to mount to the back of "The Summah Bus" to use for backing up, lighting for the rear camera (while not driving off course), etc.
Ideally, I'd like to control them from the switches at the deiver's seat and the easiest "unused" switch it the red flashers switch. I unhooked the wires from the back of the red flashers (they are painted over on the outside) and hooked up my new LED spotlight... and it works!!! ... The same way red flashers do...
So my question is: is there a way to make the lights not flash? I don't know enough about electrical (but I'm trying to learn) to know what to do. Is it something back at the control panel by the driver's seat that makes them regulate flashing on and off?
I could use a "heat pump" switch and wires for power, but it doesn't reach all the way back and since in planning on mounting the spots right next to the old red lights in the back, I though these wires would be perfect.
Any suggestions?
