Old 07-23-2010, 01:24 PM   #1
Vapor Barrier question
Vapor Barrier,
I understand the concept of a Vapor Barrier, my thought is wouldn’t this trap moisture in between the wall and metal (bad) or ceiling & metal (bad) floor & metal(bad), I’m sure possible by using a rust/mildew paint or primer will be applied on the metal before the Vapor material is applied, am I missing something about the Vapor Barrier? Sorry to all if I sound like a newbie (oh I am)
jbus is offline   Reply With Quote
Old 07-26-2010, 02:21 PM   #2
Diesel Dan's Avatar
Engine: DT466/AT545
Re: Vapor Barrier question
I suggest you use the search function on this forum to see the discussions that have transpired regarding this topic. Some people have used a vapor barrier, others not. I chose not to based on the same reasoning you mentioned. I'd rather have the moisture escape rather than be trapped. It seems unlikely that you will be able to guarantee that moisture will not find it's way past your barrier. Most likely scenario is condensation on your windows trickling down the inside of the wall and onto the floor.
Gallery:
Conversion Thread:
viewtopic.php?t=4959
Old 07-27-2010, 09:42 AM   #3
Diesel Dan's Avatar
Engine: DT466/AT545
I did exactly the same thing as Dr. LuLu, except I put a layer of red rosin paper between the floor and insulation to act as a medium for absorbing and dissapating any moisture.
Gallery:
Conversion Thread:
Anyone ever use Hy-Tech#85 Barrier Coat bapos Conversion General Discussions 1 05-05-2013 10:16 PM
Vapor barriers... tyvex vs. tarpaper vs. ??? TygerCub Conversion General Discussions 2 08-05-2009 09:19 PM
