Old 05-05-2008, 09:04 PM   #1
Engine: 5.9l Diesel Cummins
Rated Cap: 20
Wagner spray painters and your bus
Has anyone considered using a Wagner power painter to shoot their bus? Everything I've been reading says it can be done. I'm thinking of trying it unless I hear back that it wouldn't work. Thoughts? http://www.wagnerspraytech.com/portal/h ... 0,747.html
About HVLP sprayers (High Volume Low Pressure)
Wagner's HVLP (High Volume Low Pressure) sprayers produce professional results with exacting control. Specifically designed to spray light bodied materials, HVLP sprayers use air to control the shape and size of the spray pattern. Whether you are spraying your deck or finishing a table, Wagner has a sprayer to suit you needs.
Level: Consumer / Professional
Project Type: Indoor - Outdoor
Project Size: Small - Medium
Surface Type: indoor furniture
outdoor furniture
lattice
wood fence
metal
stucco
Paint Type: oil-based, stain, varnish, sealer
Technology: HVLP (High volume low pressure) Air Turbine
Paint Supply Capacity: 1 quart - 1.5 quart
Available Accessories: Yes
My 1997 Ford / Thomas shorty
5.9l Diesel Cummins w/automatic tranny
Photo's of my bus build
Billsman is offline   Reply With Quote
Old 05-05-2008, 09:09 PM   #2
Rated Cap: 20
Re: Wagner spray painters and your bus
or this one http://www.wagnerspraytech.com/portal/p ... 8,747.html
Old 05-06-2008, 08:05 AM   #3
sportyrick's Avatar
Chassis: F33695
Most adhesives are alcohol based, try some of that and see if it works. It may take something stronger than isopropal, try some everclear (180 proof). If that doesn't work then try goof off. sportyrick
Old 05-06-2008, 08:34 AM   #4
phillbus914's Avatar
I used that goo gone stuff - smells like oranges, it worked great.
My Old Bus :(
Old 05-06-2008, 10:46 AM   #5
If you drink the everclear, the adhesive and paint won't matter.
Old 05-06-2008, 03:32 PM   #6
Xtevan's Avatar
Coachwork: BLUEBIRD
Cigarette Lighter fluid- naptha? worked really well on the adhesive residue under the vinyl letters that acetone and mineral spirits would not budge.
Xtevan
Bus Project Pictures
https://picasaweb.google.com/XtevanofthePlaya
Xtevan is offline   Reply With Quote
Spray Foam Question White99z Conversion General Discussions 18 11-03-2016 10:26 AM
Who knows anything about Wagner Ware? crazycal Skoolie Life 8 10-26-2012 12:15 PM
Questions for you painters putterspitt Conversion General Discussions 1 10-17-2010 10:06 AM
spray foam under floor - who has done it? ramairws601 Conversion General Discussions 6 10-16-2009 05:29 PM
Best spray gun for painting?? paul iossi Conversion General Discussions 2 05-15-2009 11:35 AM
