09-22-2013, 08:50 AM
Coachwork: Eagle
Chassis: Model 10
Engine: 6v92 Detroit
Rated Cap: 44
Wall and ceiling insulation?
Do most school busses have insulation in the walls and ceiling? Mine does and I was wondering because I see that some are tearing out the walls and ceiling to add insulation. I am thinking I will leave the ceiling as is and paint it and probably the walls too.
My bus is an 84 International Army bus.
09-22-2013, 04:49 PM
Engine: 190hp 5.9 Cummins
Re: Wall and ceiling insulation?
The inch thick yellow fiberglass bats they use in the wall and ceiling do more harm than good. It collects moisture, holds it, and causes rust. Its also wasted space that could be filled with Styrofoam.
In order to make the bus useable, no matter the climate hot or cold, you need a thermal break. No metal, or interior covering should contact the outer steel skin or ribs. It needs to be separated by a minimum 1.5 inches of Styrofoam. The more the better up to around 3 inches. After that it just becomes a unneeded expense.
Don't cut corners, or take shortcuts. Go down to the hardware store, get your self a 4 pound hammer, and a 1 inch wide, by 12 inch long cold chisel with a hand guard. Eat lots of protein, and learn to swing over your head. I can blast a 3/16 rivet off with two swings. It shouldn't take more than 5 each rivet. Do as many as you can till your arms get tired. Take a break, swing some more. I did the last one bit by bit over the last month.
After the first few hundred, you will get good at it. There are around a 1000 rivets in the ceiling and walls of a 40 ft Blue Bird Bus.
Good Luck
09-22-2013, 05:10 PM
I mostly agree with what you are saying, IF that is indeed the way most buses are insulated. Waynes must be oddballs. My insulation is about 2.5-3 inches, and was crisp and clean, for the most part, with no rust caused by it. That's what I found in the walls, at least, and the insulation I could access in the ceiling all looked the same, hence my decision to leave it. The one exception I did find was around my wheel wells. I did find a little moisture there, so I replaced with extruded styrofoam.
Brutus
09-22-2013, 07:01 PM
Engine: 3126
A Thomas bus had 2" of insulation. I did find mold under it.
09-22-2013, 07:15 PM
Wow, that picture is very enlightening for me!!! Night and day difference. Mine looked more like regular insulation and was dry and clean (mostly).
Edit: I'm actually thinking mine may be 3 or a little over. That looks like half the thickness of mine. I think I need to stop giving advice on whether or not to remove insulation, lol...
Brutus
09-22-2013, 08:52 PM
Chassis: International Amtran RE
Engine: DT466E/MD3060
I am more or less stuck at this very stage on my build. So I will pass my insight of my bus deconstruction.
1) if you have access to a air hammer and air compressor get you one... even a cheap one. I had the side walls of my bus done in 2 evenings ... probably a total of an hour in shearing off the rivet heads.
2) My 1983 ward had some chicken s batt insulation in the walls. Most of it had broken down and was a lot of dust. So use a mask. I did not find much rust but again I think this is a situation of where you live more than anything.
3) Thermal breaks are great but cant always happen. To me and this is my opinion... I think being air tight is the next best thing. Most buses has so many air leaks its not funny. So to me sealing up with some type of vapor seal is what I am planning. Then I will pack mine full of 3 inch poly iso insulation then... some type of wall material.....probably Luan.
I am really hoping this makes it more quiet and more comfortable. In the past I got a hip shot quote to have it spray foamed with close cell insulation and it was close to 1200.00. not going to happen cause I only paid 1300 for the bus?
But the best bit of advice I can over from my experience is get access to an air compressor and a air hammer.
Here is the first panel I pulled.....
Ill see if I can get a pic of its current state. I have the large 4x8 sheets of insulation in it so its kind of blocking the view.
Hope this helps
09-27-2013, 04:48 PM
I think that, in the end, it's what you're comfortable doing. I'm aware of people that's pulled their insulation (YEE GADS, BAILEY!  ) and I'm aware of people that hasn't. If your bus had holes drilled into the roof for luggage thingers (so technical Mel  ) then you're probably going to need to pull it and replace it, since most of them hasn't been resealed properly and once insulation gets wet it's useless.
All the insulation in my bus will be yanked out and replaced with pink or blue board and reflectix, but then I'm over engineering the blighter like I would the boat.
'Tace
Dog is my copilot. As I have no dog, I have no flight plan.
"If all porkchops were perfect, we wouldn't have hotdogs!" -Steven Universe
09-29-2013, 09:35 PM
Coachwork: Ward Senator
Chassis: International 3900FC
Bapos...I see you have a Ward as well and that at the top of your side panels it was appears to be spot welded together....tthats the way my sides seem to be put together...a couple of quick questions....did the air chisel break the weld or tear apart the metal?....are you going to cut the remnants of the welded seem (the part still attached below the window) off before you seal up wall?
I'm planning on tearing out the sides and the ceiling to reinsulate and reseal some of the openings....
10-06-2013, 07:56 PM
West
Yes it is spot welded and no the air chisel didn't cause any damage other than to the rivets or the sheet metal I was taking off. The rivets were expected and I am sure they will need to be poked our hammered out.
There was a little bit of a ridge there at the top of where the sheet metal and the welded in window frame come together. I am not sure what will be needed. Im kind of leaving things along till I get the windows in. But I think I will either roll them down or maybe cut off the unneeded with an air cut off tool. Anything that will make it easy to slide in the polyiso in the sides and be able to tape them up with foil type tape.
My truck will be paid off this month so there will be almost 600.00 of money freed up so I am hoping to pick up and do some more work on the bus. Ill keep you posted.
10-07-2013, 02:57 PM
I was just curious as to how you were going to handle that extra bit of metal. We started on removing those side panels this weekend and decided to use the angle grinder with cut off blade and cut just below the doubled up metal. I'm going to frame in around the windows so leaving that little bit of metal won't be a problem. I didn't want to cut it out, because it looked like it might be some window flashing. We'll have to see how it goes once we start to install the insulation.
10-07-2013, 11:00 PM
Let me know how it turns out. Pics. pics... pics... they tell everything.
03-30-2014, 09:55 AM
Bump.
Love these topics. Great learning for me and others.
Question for those using or thinking about using, the "Reflectix" or similar type barrier. Will you put it out against the outer skin, or in, against the inner skin?
Then will you separate the foam or fiberglass from the barrier with some type of furring strips or?...........
Thanks.
03-30-2014, 10:35 AM
Deezl Smoke
I am not going to use reflectix..... but I will be using a spray on type radiant barrier. It is to my understanding you want the reflective side to the metal skin so that the heat energy can be reflected back to the outside and not get trapped inside.
I think separating the insulation from the inner barrier is going to be different from builder to builder. I personally don't think using fiberglass is a good option unless your looking quick, cheap, or the bus wont be in your ownership very long. I think people can see what under insulated materials do over time. I know in some cases its better than nothing but if your going to spend any measure of time in this tin can you will want it to be comfortable. I don't think its any mystery that these things noisy and rattle. Doing these things will help quiet them down ....some.....and make you more comfortable. Like building a house there are a few areas not to skimp on materials.... this is one of them.
I plan on using the spray on type radiant/vapor barrier, then polyiso insulation, fir out the sides, and close it out with luan.
03-31-2014, 10:46 AM
Engine: 3126
I read a lot about "Reflectix" and it works best if there is an air gap between it and any other insulation. Check out this link:
http://www.reflectixinc.com/basepage.asp?PageIndex=581
Then click the .pdf for Air Space Requirements.
I ended up using R-Matte Plus-3/Thermasheath Polyiso sheathing. It has a refletive reinforced aluminum facer. The inside of my bus looks like the inside of the space shuttle.
03-31-2014, 01:15 PM
Air gaps are a farce, as is the little bit of tin foil. That tin foil is a marketing stunt that really has no effect.
The link provided above is for buildings with vented roofs. Our buses need to be SEALED, as they have no venting in their roof. The technology they are trying to push is the tin foil will block the radiant heat from the sun above. However, once the heat is in the building, it must be vented. Better would be to skip the reflex insulation. and to the spray foam the underside of the tin. With the spray foam directly adhered to the tin, the radiant heat from the sun is never allowed to enter the space. Also the spray foam eliminates the condensation buildup that will form on the underside of the tin roof, just behind the reflex insulation.
If you leave a air gap, and cold air get's into that air chamber, that chamber becomes a cold zone. All insulation to the outside of that air gap you left will be rendered useless.
As a builder, I have made this mistake. It cost me thousands when I had to tear apart the house and re insulate with spray foam.
AIR GAPS DEFEAT THE PURPOSE OF INSULATING.
03-31-2014, 02:02 PM
Engine: 3126
I agree, that is why I used the foamboard. I didn't see the "Reflectix" adding any R value without it. I also plan to spray foam the last inch to seal everything. I used a combo of foam board and spray foam, because one I need insulation and it was too cold to spray. Two to save some money.
05-12-2015, 10:20 PM
Once the pink foam is installed do I re-install the ceiling steel that I removed to get the fiberglass out? to return the structural integrity of the bus?
I would assume that an additional layer of something would need to go over the re-installed ceiling to keep the screws from transferring heat from the bows and the rivits on the outside.
The same thing with the walls?
I have to figure that pat of the bus strength is from the added support of the interior steel fastens to the bows.
thanks
Cliff
05-12-2015, 11:57 PM
The interior panels are of very little structural importance.
I removed mine and have driven the metal tent around now for months. Its just fine.
05-13-2015, 10:57 AM
thanks
Cliff
You need to strap your ceiling.
I need to make a sticky on how to insulate.
Go read build threads. Almost no one reinstalls the metal ceiling.
Start with this build thread.
http://www.skoolie.net/forums/f11/th...ime-10138.html
05-13-2015, 01:18 PM
this is one of the better youtube builds if not the best-
