Old 10-10-2019, 01:26 PM   #1
Rated Cap: 71
Wall panel question
I have seen a lot of videos about doung a full gut which im in the middle of doing. My question is has anyone removed the metal under the wall panels and insulation? Is it safe?
CaptianAmerica44 is offline   Reply With Quote
Old 10-10-2019, 01:33 PM   #2
Engine: 466e
Rated Cap: its Yuge
Everything I have read says the chair rail is part of the supporting structure of the body
MambaJack is offline   Reply With Quote
Old 10-10-2019, 01:48 PM   #3
You'll wanna leave that bottom bit in, as it's supposedly a structural element. We stuffed insulation behind that panel and covered it with our new wall.
Old 10-10-2019, 02:22 PM   #4
Rated Cap: 71
Alright. Thank you! I took the rivets out of one section and thought this might not be a good idea
Old 10-16-2019, 07:44 PM   #5
Coachwork: Tomas
Engine: 7.3l
Here my plane
I'm thinking 1/8 to 1/4 wood paneling that I can get at home depot Canada. It's smooth and it's white. Easy glue and staple to my straps. In emergency it will easily be removed if ever need be.. No pics as I'm not quite at that stage but hopefully this month
Frogpondfoug is offline   Reply With Quote
