Old 05-10-2016, 06:55 PM   #1
New2Skool's Avatar
Coachwork: Carpenter Body
Rated Cap: 65 to Zero. Folding Chair
Cool Wall Removal
Hello all,
Thanks for the help on my previous questions and requests for advise.
I would like to remove the lower wall section / chair rail section of walls from my Carpenter International Bus.
Is this possible?
Is it a good idea?
Are the four rivets per rib attached to the exterior wall or do they stop in the rib?
Attached is a link of the picture.
http://picpaste.com/utaaXB2C.jpg
Thanks,
DLJIII
D.L. Jones III
"The Independence"
98 International
New2Skool is offline   Reply With Quote
Old 05-10-2016, 07:03 PM   #2
Chassis: Genesis
There have been discussions and diagrams of this before. It is structural and an extremely bad idea to remove.
Timelord is offline   Reply With Quote
Old 05-10-2016, 07:22 PM   #3
New2Skool's Avatar
Sense
Ok, that makes sense.
I do plan to remove the actual seat rail itself.
D.L. Jones III
"The Independence"
98 International
Old 05-10-2016, 10:43 PM   #4
Depends on how it is constructed. On most Skoolies, the chair rail is a critical structural element that ties the body to the lower chassis & frame and needs to be left in place. Do some homework on your unit before getting crazy with an angle grinder and cut-off disks.
Old 05-10-2016, 10:51 PM   #5
New2Skool's Avatar
Ok, I can check.
I don't like the chair rail.
It is in the way and would be much easily to insulate the wall with more access.
If it helps my Bus is a 99 3800 international, carpenter body.
I will have to slide around under it and check everything.
Thank you
D.L. Jones III
"The Independence"
98 International
Old 05-10-2016, 10:59 PM   #6
Actually, the area below the chair rail makes an excellent chase for electrical & even plumbing.
Old 05-11-2016, 01:51 AM   #7
tincaneasybakeoven's Avatar
Year: 95
Coachwork: Amtran ss-33
Chassis: Int 3800
Engine: dt444E
Rated Cap: 29,000
yep, my d side had 2 -1" heater hoses and a sheet metal cover for the remote heater. using the remote heater to add extra radiator capacity for an under bus radiator. label says 90,000 btu's. might keep the dam fan from locking up and drawing hp.
claim common law i, a man; claim.... on facebook
if your not a man our doing it all wrong-kp
tincaneasybakeoven is offline   Reply With Quote
Old 05-11-2016, 02:13 AM   #8
Chassis: IC CE
Engine: T444
Originally Posted by New2Skool View Post
Ok, I can check.
Thank you
I'd suggest against it, as several people have said it could be structural. It can be used to ferry wiring and plumping easily and honestly you probably will not notice it as much of it will be covered up depending on how you wish to make your skoolies interior look.
the pocket created by the lower side wall actually makes it far easier to insulate. At worst you can slit 3 small lines to create a "bendable" area and slide the board insulation in. However if you go spray foam its moot as you can just angle the spray nozzle as needed.
Azuleslight is offline   Reply With Quote
Old 05-11-2016, 07:41 AM   #9
New2Skool's Avatar
Talking Thank You
Thanks for the advise.
The lower wall panel stays the way it is.
I will work around it.
Thanks for the help.
D.L. Jones III
"The Independence"
98 International
Old 05-11-2016, 08:01 AM   #10
I really like your enthusiasm and your positive attitude, man.
Roll Your Own Build Thread
Old 05-11-2016, 04:51 PM   #11
New2Skool's Avatar
Smile Thanks
Thank you, I love my Bus
D.L. Jones III
"The Independence"
98 International
insulation, interior, removal, seat, walls
