Old 08-21-2006, 10:37 AM   #1
w1bmw's Avatar
Year: 1982
Chassis: TransitLiner
Engine: Cummings
Wall sheathing - MCP II
I got my side walls about 90% done this weekend. I still need to do the compartment dividers, but I'll do that later in the week. Here's what I plan to do with the seat rails (the other 10%). Any comments?
Pictures up on the gallery later this week.
Zim (W1BMW) - Somewhere East of Tampa
'82 Thomas TransitLiner - The Mobile Command Post II
https://www.skoolie.net/gallery/MCP-II
w1bmw is offline   Reply With Quote
Old 08-22-2006, 01:34 AM   #2
wtd
wtd's Avatar
Year: 1982
Coachwork: Thomas TransitLiner
Looks like it'll work.
I did mine like this -
I considered the way you plan, but decided on the above for a couple of
different reasons.
- didn't require horizontal chaseways for water.
anything that will leak is below the bus floor, in the 'basement'
just as in a house. I used less than 20' of water supply pipe and
had no reason for a chase large enough for water pipe that would
run the entire length of the bus. Also, don;t see many houses with
horizontal pipe runs in the walls, most are in the basement or
crawlspace with only risers in the walls. So no reason to go against
this practice. Still room for electrical run in the lower portion of the wall -
about 3/4", but I ran mine through the overhead compartments, just for
access, since I seem to change things a lot
- the panels are inexpensive, easy to install and easily replaceable if
damaged. Also easy to redecorate of you wish as the panels are
removable - simply remove the panels, recover them and the rub
rail and Voila - new decor.
- I didn't want several inches of intrusion into the room. The appearance
of the intrusion is greater than the actual space taken up, but with
the lower part of the wall flush with the top part, or nearly so, it gives
a greater impression of space and surface continuity. Don't see many
houses with the lower 1/3 of the wall stickin' out 2 or 3 inches into the
room.
Still under construction it looked like this -
The grass paper wallpaper and brown has been changed and is now gray carpet with gray trim.
Here it is while redecorating -
I also removed the 'wire channel' shown in your sketch and replaced it with a valence on one side and compartments on the other (since replaced with just a shelf), that also serves as a cable tray. This also gives a better mounting surface for curtains, shades etc., rather than trying to put up a curtain rod in steel.
Looking forward to your pictures.
Just a few thoughts, there's as many ways to do this as there are busses and people - enjoy it
The Rolling Motel Room
Where DIY meets WTF
wtd is offline   Reply With Quote
Old 08-23-2006, 05:50 AM   #3
w1bmw's Avatar
Year: 1982
Engine: Cummings
Yep, and exactly why I love this site! After finally getting the internal radiators/passenger heaters out last night, I think I'll leave the plumbing in the 'basement', too. As for the bottom 1/3 of the wall being visible? This thing is gonna be so crammed full of crap that I wonder if ANY of the walls are going to be visible!
Thanks for the ideas!
Old 09-03-2006, 07:42 PM   #4
GoneCamping's Avatar
I saw this post and your drawing for the wall and thought, boy this is familiar!! I haven't actually got that far yet, but it's pretty much the same thing I had in mind. My plumbing will be done mostly under the bus, and I'm trying to keep most of it inside the baggage compartment I'm building under the center of the bus. This way the plumbing is NOT exposed to outside weather...a really important issue to me since I'm a full timer and my bus will replace my TT...
I don't know how yours went, but I found that removing ANYTHING on my Thomas has been more trouble than it's worth...and have just left some things alone.
I've got it all figured out except what I'm going to do with the ceiling. The Kool Seal on the roof helped, but would like something on the ceiling....can't be too thick since my bus is low inside height....
*Cliff*
...Your home has brake lights
1994 Jeep Grand Cherokee
Chesapeake, Virginia
GoneCamping is offline   Reply With Quote
Wall outline , is there a easy way Six Four Conversion General Discussions 4 11-16-2012 10:43 AM
Wall Framing Issue RUskoolietailgater Conversion General Discussions 8 08-01-2011 11:26 AM
Through the wall A/C option? mouse059 Conversion General Discussions 2 06-04-2010 08:56 PM
Off-the-Wall Conversion Ideas Steve Conversion General Discussions 6 03-07-2010 04:29 PM
Interior wall questions the_experience03 Conversion General Discussions 4 07-07-2008 05:08 PM
