Old 03-18-2014, 03:30 PM   #1
Chassis: B3800 Short bus
Want to add a vent fitting to a polyethylene tank
Hello all.
What are my options for adding a fitting to a polyethylene tank?
Are compression fittings my only reasonable solution?
Anyone have a good resource for purchasing tank fittings?
Thanks!
Old 03-18-2014, 03:47 PM   #2
roach711's Avatar
Rated Cap: 19
Re: Want to add a vent fitting to a polyethylene tank
One of our members added some fittings to his poly tank.
Here's the thread - scroll down to the fourth post.
http://www.nomadicista.org/viewtopic.ph ... ene#p19751
The Roach Motel
Old 03-18-2014, 04:03 PM   #3
Wow... That's some good thinking.. I have a router and am willing to give it a shot.
With that info in hand, I was able to find an ok price at http://www.pellandent.com/default.aspx for the fittings. I ordered 3 1/2" fittings just in case I screw up
plastic drum threaded bung fitting help needed bansil Plumbing, Water and Waste 10 03-12-2014 04:01 AM
fitting for city water? lornaschinske Conversion General Discussions 8 01-23-2011 01:24 PM
Fitting Seat Belts pipsqueek Conversion General Discussions 1 10-04-2010 01:41 PM
Black/Gray Tank Vent kamoo Plumbing, Water and Waste 9 06-24-2009 09:29 PM
Blackwater tank vent Elliot Naess Conversion General Discussions 9 03-04-2009 07:32 PM
