Old 05-23-2018, 01:50 PM   #1
What Tranny Is in Here?
What tranny would likely be in this bus. 99 Genesis Transit, DT466, Allison 5sp.
Push button shifter, tell me it's not a 545.
Old 05-23-2018, 01:52 PM   #2
Tryonis's Avatar
Chassis: TC2000 RE
same panel as my MD 3060
Tryonis is offline   Reply With Quote
Old 05-23-2018, 01:54 PM   #3
What Tranny is This?
Seller just replied and you are correct, it's a 3060.
Old 05-23-2018, 02:05 PM   #4
Tryonis's Avatar
Chassis: TC2000 RE
Mine has a slightly different screen. It shows max gear on left and actual gear on the right which changes as it shifts.20180523_135826[1].jpg
Old 05-23-2018, 02:11 PM   #5
What pros or cons or difference can I expect between a 643 and 3060?
Old 05-23-2018, 02:14 PM   #6
Tryonis's Avatar
Chassis: TC2000 RE
OD for one with the possibility of unlocking 6th gear. I chose a bus with a 3060 after reading this site for 2 months. I think from what i have gathered you can't go wrong with either.
Old 05-23-2018, 02:34 PM   #7
Year: 1994
Engine: DT408 6.7L L6
My understanding is that the WTEC shifter (push button) could be put on various models... Do I have that incorrect?
~Alf
My Build Thread!
djdalfaro is offline   Reply With Quote
Old 05-23-2018, 02:45 PM   #8
I have heard that the push button shifter was available on the 2000 series. I have not seen one yet.
However, the 2000 series was not available in '99.
As far as I know the only transmission you are likely to see in a '99 that is "push button 5 speed" would be an MD-3060.
