Old 03-01-2008, 09:57 PM   #1
Chassis: Carpenter
Engine: ISB Cummings
Water from window corners-
Hi All,
We think we've located the source of our leakage problem. In my earlier post regarding water issues, Sean F hit the nail on the head when he said that it was coming through the windows and running down the walls. Now, someone (I believe it was ShortBus) suggested caulking to alleviate this problem. How do we go about doing that? Would you caulk both inside and out? Where would you put the caulk?
We really want to avoid having a rusty and disgusting cesspool going on under our floor after it is laid. will caulking be enough to prevent that?
Also, we've taken all of the bazillion screws out of the metal wall paneling, but the paneling is attached to the underside of the windows. Any tips on how to remove it? Did most of you remove it or leave it in?
We're considering levering it intact. We'd levering it up and then treating the inside of the walls, re-insulating, and sealing it back up before putting a 1/2 (or thicker?) blue-board foam insulation on top of it, and then finishing it off with maybe some bead-board paneling... what do you think, overkill? or is that reasonable? We are planning on being in some pretty heavy winters.
And finally, do you think we'd have less (or more) trouble with water leakage if we did it this way?
Sorry for the multi-topic thread, but if anyone can handle it, it'd be you guys!
Fifer is offline   Reply With Quote
Old 03-02-2008, 08:20 AM   #2
swinada's Avatar
Re: Water from window corners-
we kind of had the same problem. First we decided to cut off the inside panels to be able to easier access the frame and rust proof it. then we decided to remove all the windows and replace them with RV style windows, so the rest of the panels was removed too. We filled the walls with Styrofoam insulation as well as the empty window frames. Covered the outside with 18 gauge steel.
we used POR-15 http://www.por15.com to tread all rusted parts. (as well as the not rusted yet parts)
If you decide to just caulk your seams make sure you remove all the old caulking first, a heat gun makes that job easier.
Proud owner of a: 1996 Thomas Safe-T-Liner,Cummins 6CTA 8.3Lt diesel, Allison AT.
https://picasaweb.google.com/swinada/BusPictures https://www.swinada.com/bus.htm
https://lh4.ggpht.com/swinada/SL91F-b...opbussmall.jpg
swinada is offline   Reply With Quote
Old 11-30-2009, 08:56 PM   #3
Coachwork: THOMAS
Chassis: SAFE-T-LINER
Engine: CAT 3116
Rated Cap: 83
Hey Swinada, do you have any more pics of your conversion? I'm interested in seeing what you did with your walls. I was originally going to build a sub-wall and leave the steel but after seeing your rust maybe I will tear mine out also.
BUSBOZO is offline   Reply With Quote
Old 12-01-2009, 06:04 PM   #4
Coachwork: THOMAS
Engine: CAT 3116
Rated Cap: 83
Yeah, Smitty I think water was leaking in at some point. I have a spot on the driver's side rear inside wall that actually has a rust hole in the steel panel AND also right at the chair rail. I'm thinking I should cut the steel panels off rip out the old insulation and rustproof the beams. Then figure out what I want to do about my wall.
I also want to reseal all my windows but WOW, I think its going to take me FOREVER to try to get the old caulking out.
Old 12-02-2009, 05:00 PM   #5
Coachwork: THOMAS
Engine: CAT 3116
Rated Cap: 83
I thought about skinning the windows. It might sound crazy.. But I don't want to take away from "Bus" look on the outside. I was thinking of maybe just blacking out and sealing the windows that will be blocked on the inside and then framing and insulating over the inside of the windows. What do you think?
Old 12-02-2009, 05:19 PM   #6
Diesel Dan's Avatar
Engine: DT466/AT545
I'm going through a similar decision process right now. I think I'm going to skin the blocked windows though. Main reason being that if you cover the windows with interior walls and cabinets, etc, and then get a leak, you probably won't see it happening. So I think I'm going to go the safer route or skinning the windows, since there is less chance of leakage. Plus you get added space for insulation by removing the window.
Gallery:
Conversion Thread:
viewtopic.php?t=4959
Old 12-02-2009, 08:33 PM   #7
Coachwork: THOMAS
Engine: CAT 3116
Rated Cap: 83
hmm... decisions, decisions.
help on black water and grey water hookups heath692 Plumbing, Water and Waste 8 04-18-2015 05:57 PM
water tank and quality of water bansil Plumbing, Water and Waste 12 03-01-2012 09:40 AM
Saving Water/Water Reduction Redbear Conversion General Discussions 9 10-06-2009 02:37 AM
12V Water pump for fresh water? ezbme Plumbing, Water and Waste 1 05-29-2009 06:26 PM
Black water/ Gray water tank travlenhippie Plumbing, Water and Waste 3 10-21-2008 08:53 PM
