Old 07-24-2016, 03:21 PM   #1
Year: 1987
Engine: 6.9L Diesel
Water Heater discussions: Tank, Tankless, LP/Electric, and DIY
Hi All,
So I have spent some time yesterday obsessing over various water heaters, and my conclusion was that it's hard to find a good water heater, especially at a good price.
I will summarize my findings below.
LP RV Tank Water Heaters: These come in 6 gallon or 10 gallon and are vented towards the outside. New they cost $600+ and used they go for about 200-300.
PROS:
-They are reliable and replacement parts are standard so they are relatively easy to repair.
-They are designed to operate in RV's
CONS:
-They will limit the quality/duration of shower one takes and will make back to back showers difficult without compromising ones (your wife's) shower times.
-They are limited by their tank size, they use more propane than a tankless LP water heater because they keep the water in their tank at a steady temperature.
LP RV tankless "on demand" water heaters: These cost $1000+ new, I don't see these used. Different water heaters will have different Gallons Per Minute ratings.
PROS:
-They are efficient with propane use and will not be using propane when idling.
-Their output are only limited to your water source size.
CONS:
-Their parts are specialized and exclusive to the manufacturer, making supply limited and repairs costly.
-Some claim that the quality of water is compromised by their mysterious heating process
-Pricey
Residential tankless "on demand" water heaters: These cost $100+ new. They are available as electric or LP gas, the electric water heaters use 10,000 watts+
PROS:
-They are cheap
CONS:
-The cheap ones have a lot of reports of breaking easily.
-many complain the vent costs more than the water heater themselves.
-all of the RV tankless cons included
Residential Tank Water heaters:
I have read about these being used in skoolies (such as Turfs bookmobile) but I know very little about these being used in skoolies, so I will not PRO/CON these.
After reading all of these I recall someone talking about their off grid shower on reddit, link here using an electric water bed heater as a heating element in combination with an Insulated RV holding tank. Which I found to be very intriguing.
PROS:
-Low cost, relatively low energy usage(they reported using about 700watts a day via 120v for the shower).
-Solar compatible
-Does not use propane
CONS:
-Plastic Tanks maybe not designed to heat up to 100 degrees
-Takes up space.
Things to note:
- "In an average home, showers are typically the third largest water use after toilets and clothes washers. The average American shower uses 17.2 gallons (65.1 liters) and lasts for 8.2 minutes at average flow rate of 2.1 gallons per minute (gpm) (7.9 lpm)." Source
-Low flow showers use 1.5 GPM
What I am hoping is for
1. Your input and opinions
2. Your experiences with good water heaters and bad water heaters and how long you've used it for, model numbers and brands would be appreciated as well.
Old 07-24-2016, 03:27 PM   #2
stevofor's Avatar
Engine: 8.2 Detroit Diesel
I got an ecotemp off of Amazon for a few hundred dollars. It works great on demand lp.
stevofor is offline   Reply With Quote
Old 07-24-2016, 05:45 PM   #3
Stu & Filo. T's Avatar
Coachwork: Crown / Pusher
Your living in a RV now, you don't take a average shower you take navy shower, wet, soap rinse, out.
Old 07-24-2016, 06:58 PM   #4
Year: 1987
Engine: 6.9L Diesel
Na man,
I'm fine taking navy showers, but my wife needs a full shower. It's not a conversation I want to have with her.
Old 07-24-2016, 08:20 PM   #5
I've been using my Eccotemp L5 in my outdoor shower stall for a year on August 15th... Bought from Amazon for $118 total shipped!
If I do not incorporate into my bus, I will be going to the Eccotemp L10, because it has built in flue ductwork.
Eccotemp is proven and tested by me, and I will not consider anything else.
In almost a year... I'm 1/2 way through my 3rd. 20lb bottle of propane (bbq grill size)
They claim 20 hours of hot water from a 20lb bottle.
I can throttle my inlet water hose and hit 190°
Old 07-24-2016, 08:27 PM   #6
superdave's Avatar
Chassis: thomas
Engine: 8.3 cummins
Rated Cap: 11 window
they are the greatest! 2 years now no problems
my build pics
Old 07-24-2016, 10:16 PM   #7
Alan N's Avatar
Year: 1975
Chassis: Gillig
We have been using a cheap Chinese on demand water heater (Marey brand I think) for eight years now.
I don't have it vented to the outside (neither is the gas range).
Other than being a little bit fussy about water flow it has been trouble free.
I would definitely recommend this kind of water heater.
Alan N is offline   Reply With Quote
Old 07-24-2016, 10:35 PM   #8
Water pressure is so high here.... I can scoot a gallon jug of water 30' across the concrete pad, and scoot heavy log chain across concrete about 20'
That pressure will be another thing I'll miss when I move
Old 07-26-2016, 08:12 PM   #9
Year: 1987
Engine: 6.9L Diesel
Thank you all for your input, I will now put the eccotemp L10 back on my radar, it says outdoor use but if I have the flu exit outside this will be fine to use indoors?
Old 07-26-2016, 10:47 PM   #10
I built a cover and flue for my L5 and vented it toward the outside the storage building... Then I put a carbon monoxide detector in the same enclosed area... Ran hot water for almost an hour and detector never went off.
I know it's a liability issue for Eccotemp, but if you think about it, the only time it kicks on is when you command it to. Example: running shower or hot water in sink. I won't use any flame or fire without a functional carbon monoxide detector.
I have full access to a HVAC vocational classroom, so I had all the supplies and tools I needed to feel confident about my ductwork.
Then I bought a METAL SCREENED dryer vent at Home Depot for around $14, it has a large outer flange that will seal & screw very well.
I did notice the heater's exhaust did not have enough force/flow to open the vent's flapper, so I just used a binder clip to hold it open. And the screen keeps the creepy crawlies out... Heat or cold, not so much... But it's not much trouble to pull the binder clip, and just clip it back on the shroud.
I kept my flue short and through the wall with a 90° elbow.
This setup works well for me... Your mileage may vary
There's a lot of YouTube videos with a lot sketchier setups than mine!
Compare the tops of the L5 & L10 and you'll see the L5 is harder to vent out.
Old 07-26-2016, 10:49 PM   #11
Year: 1987
Engine: 6.9L Diesel
Will you share pictures of your setup (or something similar?) pretty please?
Old 07-26-2016, 10:54 PM   #12
I've got it set up for outdoor shower stall at moment, (because I didn't finish indoor shower pan yet) but it'll only take a minute (tomorrow) to assemble & snap a pic.
Old 07-26-2016, 11:38 PM   #13
Make sure you run your joints in right direction... Think of "exhaust flow", like water flow
It's not the prettiest, it was pretty much a mock up and experiment... I used a used piece of pipe elbow we had from a 40gal. gas water heater.
I used a left angle from Eccotemp because I mounted on a interior right angle wall, instead of outside wall.
If I had put it on the outside wall, I wouldn't have used the horizontal pipe, and would have shortened the pipe on dryer vent.
Overall, it's under 3'
I'll mount it on heater tomorrow evening and grab a pic
Old 07-27-2016, 02:29 PM   #14
Year: 1987
Engine: 6.9L Diesel
Wow nice! Thank you for sharing, that definitely helps. When you say "right direction" are you just referring to towards outside?
Old 07-27-2016, 06:04 PM   #15
Right side versus left side
Edit: wait....
Right direction means the pipes need to overlap in the right direction so exhaust flow doesn't come through the seams...
Like rain gutter downspout ... If you install it wrong direction, water comes out
See these joints below? If they were opposite, rain or exhaust would push outward and leak because of positive flow.
Old 07-28-2016, 12:05 PM   #16
Like MM, I went with an Ecoptemp L5 though I went a step farther with the installation. I use both a CO alarm and a propane alarm. I added a sealed metal cover so all combustion air comes from under the bus and all exhaust vents directly through the body of the bus. As others have reported, the Ecotemp is fussy about water flow. Once I installed the Ecotemp recommended water pump the heater has worked flawlessly. I also installed a recirculating system to assure a constant water temp at the spigot without wasting water waiting for the hot water to arrive. Jack
A pic of the sealed metal shell that houses the heater and pumps..
Exhaust vents through former window opening on the left, the black tank through the right,
Pic of completed water heater closet at rear of bus.
Old 07-28-2016, 01:23 PM   #17
Nice work, ol trunt! That looks clean and elegant.
BusFiend is offline   Reply With Quote
Old 07-30-2016, 11:45 PM   #18
rjnye79's Avatar
Engine: T444e
So, why do the manufacturers state that these units should not be permanently installed or plumbed into any kitchen or shower fixtures?
rjnye79 is offline   Reply With Quote
Old 07-31-2016, 01:38 AM   #19
Corporate liability compels the manufacturers to list them as "portable, outdoor" units. They work great in a skoolie, with proper installation and safety precautions.
Old 07-31-2016, 04:35 AM   #20
Offgr1d's Avatar
Chassis: VanHool T945
Engine: Cummins M11
Rated Cap: 47,000
I use the Marey tankless LP... Just used short duct up to roof vent. Vent pipe only gets warm to touch after a good 10min plus shower. No limit to my hot water usage. I have used it everyday (sometimes multiple times a day) for over 1 year now. Im only on my 3rd BBQ tank... I couldn't praise this unit enough. Like another mentioned - you need enough water pressure to trigger it on.. A good RV pump or two helps. This unit hangs on wall, attached a gas flex line connected to a BBQ regulator. It has a duct vent on top ready for exhaust. Works perfect.
Ohh, and I used a top of the line Airstream tanked RV water heater before. They are the worst. I would never do a tank... Short shower / gas hungry / wait to heat up / runs out of water.... BBQ tank used in less than a week with two people taking showers..
Just my 2 cents from hot water RV experience....
Offgr1d is offline   Reply With Quote
