Old 06-22-2005, 04:27 PM   #1
Send a message via Yahoo to phillip266
Water Injection Milleage Help
Here is a great link i found for
building water injection system
for only about $5 well worth it
http://www.motherearthnews.com/library/ ... ion_System
Cool things happen when Great Minds come togather :)
phillip266 is offline   Reply With Quote
Old 06-22-2005, 10:41 PM   #2
Eric von Kleist's Avatar
Year: 1985
Coachwork: ThomasBuilt
Rated Cap: 60
Hee, hee. I'm an old fart, I guess....I actually got that issue in the mail, way back when... LOL
Eric von Kleist is offline   Reply With Quote
Old 06-23-2005, 08:43 AM   #3
trx
trx's Avatar
Chassis: Chevy C-60
Engine: 8.2L Turbo Detroit Diesel
Send a message via ICQ to trx
I should attempt to install water injection on my engine (8.2 turbo). Since my engine doesn't have any sort of air cooler this would really drop the air temp after going through the turbo. Such a system is not as cheap and simple as what you found for naturally aspirated gas engine but simple enough I could probably assemble something myself. This page pretty much shows everything you need:
http://water.lovehorsepower.com/index.html
You basically need a water tank, water pump, solenoid controlled valve, pressure switch (for detecting boost from the turbo),spray nozzle(s) and of course hoses and fittings. The only expensive part is the water pump. The kit above uses a SHURflow High Pressure pump (8000-543-23...about $80.
trx is offline   Reply With Quote
What kind of mileage do you get? Steve Conversion General Discussions 182 05-06-2019 10:06 AM
Air injection (emissions on the engine) bapos Mechanical and Drivetrains 1 06-13-2011 11:57 AM
Black water/ Gray water tank travlenhippie Plumbing, Water and Waste 3 10-21-2008 08:53 PM
hydrogen peroxide injection? boojiewoojie Conversion General Discussions 7 08-08-2007 09:39 PM
Propane injection ,extra horse power on a hill ? mike Alternative Fuels | Electric, Propane, Wood Gasification, etc. 7 07-20-2006 12:03 AM
