Old 10-27-2009, 11:50 AM   #1
Papabear's Avatar
Coachwork: ward
Chassis: IH
water line winertizing
Has anyone installed an air connection in thier water system to "blow out" the lines for winter. I think this would be easier than pouring all the pink stuff in the lines, and less expense. You'd have to make sure you did not over pressure the system. What am I missing?
"I've never been lost, but I been mighty confused for several days"
Papabear is offline   Reply With Quote
Old 10-27-2009, 03:28 PM   #2
Papabear's Avatar
Coachwork: ward
Chassis: IH
Re: water line winertizing
Actually started the first of the plumbing. Using PEX lines, I did notice I had a couple low spots in places. That's what brought up the question. No turning back now.
Old 10-27-2009, 06:00 PM   #3
Are you planning on using Check Valves? I have read of some people putting them on their showers, sinks, and so on. Just curious how one would drain their pipes with those in place. I figure having a blow out would be handy along with the low-spot drain. Just open the blow out and drain to let air in and water out.
Old 10-27-2009, 07:47 PM   #4
GoneCamping's Avatar
The ideal way to winterize is to use both compressed air and the pink stuff. Using air is easy, you pick up a "Blow Out Plug" at any RV dealer (they are cheap) and screw it into the fresh water hose connection... keep the pressure low or you could blow out more than water.
However, even after you do that, there are always low spots that left over water collects in, and subsequently freezes and possibly expand enough to burst your pipe. There are other things to consider too, even a few drops of water in the wrong place like a faucett or pump impellers will also cause problems once it freezes.
Using the pink stuff (and that stuff is cheap too) eliminates any and all problems, you flush the lines and it is all replaced by this stuff, all the nooks & crannies.
The more experienced RV'ers like to use the pink stuff first, then drain it, then blow it out as they don't want to leave the stuff in the lines all winter. Myself I just used the pink stuff and leave it in there.
*Cliff*
...Your home has brake lights
1994 Jeep Grand Cherokee
Chesapeake, Virginia
GoneCamping is offline   Reply With Quote
Old 10-27-2009, 08:33 PM   #5
We tried gravity drain of a motorhome system at work a few years ago. When we added water in the spring, we found there had been a little water left in the pump body that hadn't drained. The body had cracked and the pump was shot. Blow it all out and/or use antifreeze!
help on black water and grey water hookups heath692 Plumbing, Water and Waste 8 04-18-2015 05:57 PM
Water bleed port in the air line? TygerCub Conversion General Discussions 3 03-06-2012 09:24 AM
WATER LINE lornaschinske Conversion General Discussions 5 02-12-2011 11:59 AM
Black water/ Gray water tank travlenhippie Plumbing, Water and Waste 3 10-21-2008 08:53 PM
Alaskan oil Bus line Wilcosd Skoolie Conversion Projects 5 04-27-2005 06:21 PM
