Old 10-29-2018, 08:55 AM   #1
Dead pirate's Avatar
Coachwork: myself
Chassis: amtran
Engine: international dt466e allison md 3060
Rated Cap: 13 ton or so says the tit
Water pressure
I Can't produce enough pressure to activate my on demand hit water heater. Even when directly hooked up to a hose.
This is my experimental layout. The hose has less pressure than the pump.
Confused. Any hints or tricks. I'm no plumber.Click image for larger version
ID:	26910Click image for larger version
ID:	26911Click image for larger version
Dead pirate is offline   Reply With Quote
Old 10-29-2018, 10:11 AM   #2
Pizote's Avatar
Coachwork: ICCORP
Chassis: CE300
Rated Cap: 16
There should be an in and out direction for hookups. I know... it’s the obvious, but it’s imlortnt to double check.
Follow my build - and adventures at https://www.facebook.com/pizote.adventures
Pizote is offline   Reply With Quote
Old 10-29-2018, 11:00 AM   #3
Coachwork: myself
Chassis: amtran
Thanks. But that's not it. It works. I'm just not getting ass much pressure as i need. It needs a certain amount to much the got water heater in.
Old 10-29-2018, 11:22 AM   #4
Pizote's Avatar
Coachwork: ICCORP
Chassis: CE300
Rated Cap: 16
Are you getting pressure in and just not out or both? My MiL has one of these (similar) flash heaters in her bathroom and while pressure going in is fine, the heating coils reduce the pressure to make sure the water is heated rather than just passing through. This causes for a less-than-pleasurable shower as it tends to dribble more than spray.
Old 10-29-2018, 11:30 AM   #5
If you open the cover on the pressure switch you will likely find an adjustable pressure screw to increase or decrease the water pressure. might be a diagram to show which way to go.
