Old 12-18-2011, 04:58 AM   #1
water tank above head height
Hi skoolies,
I'm building a housetruck and want to install a round, upright 75 or 100L water tank above head height (it's for drinking water and is gravity fed). I was going to put it in the centre of the truck, but behind the back axle by about 2metres (9.3m, 10 tonne truck, with a 4.85m wheelbase). The tank isn't baffled but it is higher than it is wide (460W and 550 or 690H) so I don't think water movement will be such an issue. I have a grey water tank (200L) and a freshwater tank (180L) under the deck one each side of the truck and between the axles. I could probably do with more weight under the deck, relative to what is in the house.
(sorry for all the metrics!)
Does this sound like an issue with weight and being top-heavy, or too far behind the back axle? Are there rules of thumb for working things like this out?
I thought it was ok, but now I've written this out 75 or 100 kg sounds like alot. I could go to a 50L/50kg tank...
kouka2 is offline   Reply With Quote
Old 12-18-2011, 06:59 PM   #2
bus-bro's Avatar
Engine: 3208 na boat anchor
Re: water tank above head height
On skoolies we don't worry about a couple of hundred pounds. Put it where you want .
Old 12-18-2011, 07:03 PM   #3
The weight being that far back should not be a problem. Look at the data plate for the bus, and the front axle/rear axle weights. The rear axle with duallies should be rated to support a lot more weight than the front. Putting the weight behind the rear axle tends to take weight off of the steer axle, so steering would be lighter, but resistance to cross-winds might go down some as a result.
If you really want to get picky about it, calculate center of gravity like an airplane pilot. Pick a "station" to measure distance from (firewall, front axle, rear axle, front bumper, etc.) and calculate the desired center of gravity for a full load. I haven't done it with a bus, but with some head scratching it should be possible. Then have the bus weighed empty by axle or by wheel, and calculate the actual center of gravity you are starting with. The difference between the empty and the maximum would tell you where the load weight should be placed.
Or else don't sweat it. As far as being top-heavy, as long as you drive cautiously like Grandma, and aren't trying to take corners like Mario Andretti (Danica Patrick?), there should not be a problem. I think some skoolies have transported water barrels on roof decks.
You are already aware that a "smooth bore" tank will have some sloshing and delayed weight shifts as compared to a baffled tank. As long as you plan your stops and corners a little bit, you should be fine. Smooth bore milk tankers roll down the interstates every day.
Old 12-18-2011, 07:53 PM   #4
wtd
wtd's Avatar
Year: 1982
Coachwork: Thomas TransitLiner
20 gallons and 20" high? Heck it's only about 160 pounds or so - imagine a passenger seat where you intend to put your water tank.
Think it would change anything if someone sat in it?
Tom
The Rolling Motel Room
Where DIY meets WTF
wtd is offline   Reply With Quote
Old 12-19-2011, 04:42 AM   #5
the really really old skoolies use feet, inches, and pounds, for measurement
Old 12-19-2011, 12:03 PM   #6
wtd
wtd's Avatar
Year: 1982
Yup - can't teach an old dog new klicks ... er ... tricks.
Where DIY meets WTF
Old 12-21-2011, 10:05 AM   #7
Many of the freshmen in college when i taught basic math, had little conception of the metric system, and even less of reading the text....
Old 12-22-2011, 02:57 PM   #8
Thanks everyone, that's put my mind at ease. I do drive like a granny normally, but also have a tendancy to drive in some rougher places where the ground is uneven (so the truck sways from side to side alot) and the truck is fairly top heavy (I'm guessing the centre of gravity is higher in the truck than in most buses. The top of the deck is 1040mm from the ground. Plus I have a timber-framed corrugated steel roof).
Old 12-23-2011, 03:01 PM   #9
I'm in New Zealand John, and know Mr Sharkey's site, it's very cool. I think a NZer is running the forum now (haven't figured out the login since they moved the forum though).
water tank and quality of water bansil Plumbing, Water and Waste 12 03-01-2012 09:40 AM
Plumbing/Water Tank Help! vtwinmotors Conversion General Discussions 1 01-01-2009 12:33 AM
Black water/ Gray water tank travlenhippie Plumbing, Water and Waste 3 10-21-2008 08:53 PM
fresh water tank bocephus Everything Else | General Skoolie Discussions 5 12-21-2005 08:01 PM
Grey water tank skyhorse Conversion General Discussions 2 10-06-2004 08:26 PM
