Old 11-29-2011, 05:29 PM   #1
Coachwork: int
Engine: 7.3
Rated Cap: 59
weight and doors
i know the range could be quiet a bit but what do some of the busses weigh before and after the conversions, does it require a special license?
also any ideas on how to make the stock front and back door lock?
woody is offline   Reply With Quote
Old 11-29-2011, 06:08 PM   #2
wtd
wtd's Avatar
Year: 1982
Coachwork: Thomas TransitLiner
Re: weight and doors
As to the license, from what I've seen it varies by state, in CA, generally once it's registered as an RV you can drive it with a regular license. You didn't list your state, so there's no telling in your case.
For the locks, I used a normal RV lock on my side door, which is probably the same as your back door.
Needed about a 1/4" shim, the bus door is a little thinner than an RV door apparently.
On the front door as a 'down and dirty' solution, I used a couple of eye bolts and a bicycle lock. Recently I changed it to a garage door type thing which I think Lily(?), among others, showed pretty good.
The Rolling Motel Room
Where DIY meets WTF
wtd is offline   Reply With Quote
Old 11-29-2011, 06:26 PM   #3
RavensOracle's Avatar
Year: 1977
Chassis: International Harvester
http://www.skoolie.net/forum/viewtop...it=lock#p76376
This is the best thread I can find with regards to locking the back door. I like the deadbolt idea.
RavensOracle is offline   Reply With Quote
Overall Weight of Skoolie baadpuppy Conversion General Discussions 1 06-03-2011 07:48 PM
Bus titles & weight the_experience03 Titles, Insurance, Registration and Money Matters 4 08-27-2009 08:54 PM
weight of WVO nyrockingchairs Veggie Oil | WVO | Biodiesel | SVO 1 06-02-2007 03:55 PM
Bus Weight phillip266 Everything Else | General Skoolie Discussions 3 05-26-2005 09:58 AM
WEIGHT STATIONS phillip266 Conversion General Discussions 2 01-08-2005 09:53 AM
