I am making a wild guess as my (poor aching) back is not calibrated in pounds.
The school bus seats that I have removed have run 50-80 pounds each. The heavier ones being high back with seat belt.
When I converted my first bus I weighed it before and after and my best recollection is that I added around 9000 lbs. Disclaimer: It was an Eagle, not a skoolie.
I know that I am going to have to watch my weight during the conversion.
If I understand correctly, the way the buses are rated (weight) assumes 80 lbs x number of passengers.
Assuming 3 passengers per 50lb seat that would yield 290lb per 3 passengers. If you have an 84 passenger bus and remove the seats I would expect a "total load" including seats and 84 passengers to be 8120 lbs.
Somebody please check my math........
My goal on my new (to me) bus is to keep the conversion pieces under 6000lbs. The approximate equivalent of a 3/4 full bus.
I have a 265hp 8.3 Cummins and an MD-3060 trans. I don't know how your bus is equipped but if it has an 8.3 or DT-466 & 5/6 speed tranny then you will likely be in the same boat. If it is equipped with a 5.9 or T444 then I would set my weight goals a bit lower.
