Old 01-07-2016, 07:13 PM   #1
Arvik's Avatar
Year: 97
Chassis: BadMuthaFuka
Rated Cap: All of us
weld the 2 front doors to make one?
any one taken off the 2 air powered front doors, welded them together to make one door. then put hinges on and use for the front door? it is the perfect size and all.
Arvik is offline   Reply With Quote
Old 01-08-2016, 12:08 AM   #2
Alan N's Avatar
Year: 1975
Chassis: Gillig
Haven't done it yet but it's on the list.
I like the looks of your bus.
You are off to a good start.
Alan N is offline   Reply With Quote
Old 01-08-2016, 06:01 AM   #3
I've seen some folks use bolts and hardware to make the doors a one piece. I'd imagine a welder would do it!
Old 01-08-2016, 11:43 AM   #4
You certainly could, but the lack of insulation and leakage would be the reason I'd want to get a new door. Cant you find/cut down a residential or rv door?
Tippyman is offline   Reply With Quote
Old 01-08-2016, 12:04 PM   #5
Arvik's Avatar
Year: 97
i could , i just like the look of it. keeps some of the old skoolie in there with the new. noted on the insulation factor though.
Old 01-08-2016, 12:16 PM   #6
Scooternj's Avatar
Chassis: International 3000RE
Engine: T444E/AT545
Rated Cap: 75
When I can arrange it, I'm planning on a custom single piece door, with lexan and insulation inserts for mine
Captain Obvious on deviantArt
Old 01-08-2016, 02:51 PM   #7
REDD's Avatar
Coachwork: Thomsass
Chassis: FreightShaker
Engine: 5.9 Cummins 5 speed
Rated Cap: 2 ATV's and friends
The plan was to make a 1 piece 1" tube frame and use the windows and seals from the original doors, so it would sorta look stock...don't care about insulation for my ride.
Mule Bus Toy Hauler
https://www.skoolie.net/forums/f11/mu...ler-10055.html
Old 01-08-2016, 04:49 PM   #8
Chassis: B3800 Short bus
I repurposed the steel and a window from the original door and a proper car door latch to make a completely different, one-piece door. It was a quick and dirty job, though, and it is fundamentally flawed in that it is nearly impossible to seal. Tough as nails, though. I'll be making a new one out of angle iron soon.
I know a lot of people use residential doors, but that doesn't sit well with me. I used residential door latches for other uses inside the bus and one has already failed from road vibrations. Would hate that to happen to the front door!
Old 01-08-2016, 07:32 PM   #9
I welded the original doors together and mounted them on a "parallelogram plug" door hinge from a transit bus. That allowed me to keep the original look and yet solve the problems associated with the worn out original set up. Jack
Old 01-09-2016, 01:31 AM   #10
And it turned out mighty sweet Jack.
Old 01-09-2016, 07:32 PM   #11
Arvik's Avatar
Year: 97
WOW! thats what im talkin about. im gonna sniff around for one of those hinges. nice work jack
