Old 05-24-2016, 12:54 PM   #21
One more very important welding note...
Never do any welding on any vehicle with any computers on board without disconnecting the battery! You can turn a couple of grand worth of gizmos into toast in a heartbeat. Transmissions are especially susceptible...and expensive.
Old 05-24-2016, 01:17 PM   #22
Hank's P-O-S's Avatar
Coachwork: Tomas
Engine: T444e
Rated Cap: 54
Originally Posted by Stu & Filo. T View Post
"I would like to add, That the centered part does not apply to the web of a frame. but the 3/4 inch from the shoulder does."
For clarification, Is Nat saying it's ok to drill in the web as long as your more than 3/4in away from the shoulder??
No that is me. Nat only addressed the flange due to the original question I asked.
It is widely accepted and has not been debated that you can drill holes in the web of modern MDT/HDT bus frames.
"...Baler twine tie downs goin' down the road
On two bald tires and an oversize load..."
Hank's P-O-S is offline   Reply With Quote
Old 05-24-2016, 05:50 PM   #23
sdwarf36's Avatar
Coachwork: Champion
Chassis: Ford e-450
Engine: 7.3 Powerstroke
Someone should have told Champion. They welded their back bumper and rear backsplash to the Ford chassis on my bus. As did I when I made my rear bumper/trailer hitch.
Old 05-24-2016, 06:00 PM   #24
Coachwork: Tomas
Engine: T444e
Rated Cap: 54
Im not sure why you welded your trailer hitch to the frame, there is no reason to.
I think the point isn't you cant weld to the frame, but that if you say you can then people who shouldn't be welding something so important weld the **** out of the middle section of the frame and weaken it.
I specify the middle of the frame as it is most likely to crack there.
IMO there is not a good reason to weld to a vehicle frame other than laziness.
Old 05-24-2016, 06:01 PM   #25
Stu & Filo. T's Avatar
Coachwork: Crown / Pusher
They proably had them stressed relieved/ heat treated afterwards,that what we do when we weld on jet engine parts.
Old 05-24-2016, 06:12 PM   #26
And was that even the vehicle frame or a sub-frame assembly? Alot of those cutaway buses and RVs the chassis manufacturer frame ends at the rear drive axle and everything back is sub-assembly from the body upfitter. My granddad was limited in the size hitch he could get because it would be mounted to a sub-frame, not the chassis frame... Anything bigger than his bass boat and they were concerned it would eventually torque the back end off the rig!
jake_blue is offline   Reply With Quote
