Old 10-12-2016, 10:05 AM   #1
Welding on my BB.
I need to grind out and weld a new hatch strip....anyway, should I disconnect the battery as you would on a car or should I assume that the back of the bus is far enough away. Thanks.
JHerrin is offline   Reply With Quote
Old 10-12-2016, 10:07 AM   #2
Rated Cap: Your mom +1
You might get lucky, but if your engine is electronically controlled best to disconnect the battery. Very expensive if you happen to fry all the computers.
Old 10-12-2016, 02:49 PM   #3
I undid all my electrical connects. Weld is crap so I am taking it to a pro. Dang
Old 10-12-2016, 07:12 PM   #4
Carytowncat's Avatar
Where you loocated J
