Old 09-23-2009, 05:16 PM   #1
What are the basic interior measurements?
I don't have a bus yet, but I want to start working on my interior layout. I'm planning on getting a full size bus. Can anyone provide me with the following interior measurements:
1. width
2. ceiling height (center)
3. wall height
4. wheel well height/length/depth
5. distance between wheel wells
6. distance from back of driver's seat to back of bus (full size)
Thanks!
Homeskooled is offline   Reply With Quote
Old 09-23-2009, 05:18 PM   #2
Re: What are the basic interior measurements?
One more thing... I'm planning on getting a pusher. How are they configured in the back? is the floor flat?
Old 09-23-2009, 09:39 PM   #3
GoneCamping's Avatar
You've got a loaded question there, and there are multiple answers...
I can't say what every make of bus is in width, but I'd guess they are all about the same. Mine is 90" inside wall to wall...
Length is variable, but you can figure about 25-26" for each row of seating... this is not an exact measure, but general rule of thumb... Stand outside and count the windows and you can guestimate the rows of seating (each row gets a seat). Mine is a 12 window/12 row rear engine Thomas, interior length is about 34' if I remember correctly
The back of the bus has a seat that goes all the way across, and that is set on sheet metal, behind that is the motor. it is NOT flat by any stretch of the imagination.... below is a picture (sorry, best I can find right now) that shows the contour of the rear seat area with the seat removed...
As for the wheel wells, that too will vary on the make. I forgot exactly where they measured out to (it's been nearly 4 years since I laid mine out), but I remember the wheel well being 24" in lenth front to rear...
I placed closets over both the rear wheel wells, and the rest of the rear space I was able to fit a Queen mattress sideways with an inch or so to spare... The floorplan I started with came out extremely close to what I ended up with...
*Cliff*
...Your home has brake lights
1994 Jeep Grand Cherokee
Chesapeake, Virginia
GoneCamping is offline   Reply With Quote
Old 09-24-2009, 08:28 AM   #4
Thanks! Great information, and the pictures really help.
Old 09-24-2009, 08:39 AM   #5
Year: 94
Coachwork: b/b
Chassis: tc2000
Engine: 5.9
i have a 94 blue bird its a 72 pass from the driver seat back to the rear is 27.5 ft and is 96'' wide. from rear of the rear wheel well is 10ft thats on mine ..most 90s model blue bird are about the same ..... mine is a front eng bus,flat nose,,,so a pusher or a puller you well lost the same amont space...ok
the renegade
keith is offline   Reply With Quote
Measurements and isolation Letsbenomads Skoolie Conversion Projects 15 03-19-2014 11:10 PM
Measurements for a Chevy/GMC short bus. crazycal Short-Bus Conversion Projects 0 02-07-2014 02:14 PM
Can someone help me with some measurements? houseofcakes Conversion General Discussions 3 03-09-2013 05:23 PM
Basic 7.3L IDI frank-id International | Navistar Drivetrain 5 12-14-2010 11:44 AM
Basic wiring chaos Conversion Tutorials and How-to's 2 04-13-2010 12:50 AM
