Old 01-29-2015, 03:40 PM   #111
lornaschinske's Avatar
Rated Cap: 89
I bought a 4 pack of little solar step lights this week from work. I glued neodymium magnets on the little mounting bracket. Now I can mount the bracket any place outside on the steel body and have a little light. Currently, I put one at the top of the door and one a little lower down so I can see the step better and the key hole of the door lock. I also put one on the front of the bus near the door so I can see where the timer on the extension cord is in the early morning. I put a space heater in the jeep and the night before I go to work, plug the heater into the timer so I end up with a warm vehicle to go to work in (and a thawed out windshield). I "store" the timer on the extension cord in the foothold opening of the bumper. Keeps it out of the weather. I will remove the lights before I travel and put them back out where needed. No wires. No holes.
Fulltime since 2006
Old 01-29-2015, 04:13 PM   #112
We just got our months shipment (amazon auto) and wow I could poop for months on our supply of TP now
ugh...TMI
Old 02-06-2015, 11:11 AM   #113
Rated Cap: 89
Talking Sarcasm!!!
We have "sarcasm" smilies! Oh joy!
Aren't they cute. I can be sarcastic now and add a "sarcasm" smilie at each end of my sarcastic comment. Like....
I just love living in New Mexico. The weather is so lovely.
Fulltime since 2006
Old 02-06-2015, 07:27 PM   #114
Rated Cap: 89
knob on medicine cabinet
The mirror I used for the medicine cabinet was originally designed to hang on the wall from a decorative rosette on a chain and ribbon. I mounted the mirror to the medicine cabinet door using spring mirror clips. Then I used the rosette as a knob to open the cabinet door.
Also made a shallow pan using vinyl pan liner to go under the washing machine. Seems a premade plastic pan was too wide. I only have 29" in width and all the pans I looked at were 30". So I glued up a shower pan liner and glued it to the floor (PL375 is approved for shower pan liners) and up the sidewalls a couple of inches. Not that it can hold much. But I wash in cold water and the incoming water is so cold that the tub sweats a lot. I thought I had a leak at first. Then I took the front panel off and the whole tub was dripping from the water line down. I'll wait to put a drain on it until I have an extra person to help from the inside.
The liner I bought was more than enough. I guess I will use it up when I make the black and grey tanks this summer. I'm doing vinyl liner on insulated plywood box. Easier than fiberglass and should hold up for a long time.
Fulltime since 2006
Old 02-11-2015, 02:17 PM   #115
Rated Cap: 89
Finished painting the vanity. Still need to do more work on it, trim, finish up the medicine cabinet, buy/wire up lights (one on each side of the mirror), lay the little bit of floor tile (requires pulling the toilet) and order/hang a new accordian door (in espresso colour). Plus trim out the window. And that will be complete.
Fulltime since 2006
Old 02-11-2015, 08:36 PM   #116
I like blueish/green tint....stain or ?
Is that the "faux" wood look I have seen done with rubber and sponges?
I like it
Old 02-11-2015, 09:12 PM   #117
What kind of washing machine do you have?
Old 02-11-2015, 10:58 PM   #118
Rated Cap: 89
I like it
It's all latex paint. Originally painted with a Martha Stewart metallic (silver... I forget the name) over grey Kilz2 primer so that is my base coat. Next coat is Behr Marquee Semi-Gloss in Caicos Turquoise (yes, it really does cover in one coat). I used a rocker graining tool to make the wood grain effect. Next coat is Ralph Laurent Glaze in Brilliant White and used the rocker wood graining tool on it. The Martha Stewart and Ralph Lauren were OOPS! paints so I got them cheap. I mixed the Marquee myself. I need to buy some clear water based poly to seal it. Probably satin.
I really like the Caicos Turquoise. It's such a pretty colour. Goes well with the Behr Hawaiian Pineapple yellow.
I'm going to paint the galley cabinet doors the same way. Then I will put the new clear Rustoleum Magnetic paint on the doors. I'm also thinking of putting the new Rustoleum clear Dry Erase paint on at least one of the doors as well. There are benefits in working the paint dept. The new clear stuff isn't in our store yet. It was in the dept "Hot Sheet" for this week. Supposed to come in in March or April.
Fulltime since 2006
Old 02-11-2015, 11:09 PM   #119
Rated Cap: 89
A used (2005) GE Super Large Capacity top loading washing machine. The washer AND the Maytag dryer (1995?) cost a whopping $250 from a local used appliance dealer. Added an LP conversion kit to the NG dryer for $11.72 (Amazon). I love having an onboard washer and dryer so I can wash clothes on my schedual. Like today. It was rainy and windy. I didn't have to schlep my clothes to the park's laundry. I even toss a load in late at night to wash while I watch TV or a movie. I can wash the full size quilts in the washer. I can even wash the sleeping bag (all by it's lonely). I cannot wash the two king sized quilts. So I cut one down into smaller mini quilts (2 personal sized throws) & cushion cases for the daybed. I need to cut the other one down and hem the edges. Just not today.
Fulltime since 2006
Old 02-12-2015, 06:03 PM   #120
Rated Cap: 89
A little bit at a time....
Plate Storage... Love those binning strips!
Finally got the plate storage figured out. It was so simple I really don't know why I didn't think of it sooner. Maybe that's why? I just put a stepped board about 6" from the front of the cabinet. The inner step is the same height as the support frame at the back of the cabinet. Then I glued a length of binning strip to the front and back above the stepped board and rear frame. This way the dividers are supported by the stepped board and rear frame while being separated with the binning strips. I used cut down paint stir sticks (again) as the dividers. I have some of that non-slip shelving cushion on the bottom of the shelf.
Close up of the binning strip in the back of the cabinet. I think I need to paint the dividers at some point. The interior of the cabinets are painted with interior semigloss latex paint (Behr Ultra Pure White 3750). This particular cabinet is 18" deep and 22" wide.
Fulltime since 2006
6-lug rims odee Classifieds | Buy, Sell, Swap 0 10-26-2008 05:16 PM
Dayton Rims colliervilledave Conversion General Discussions 4 03-27-2008 11:02 PM
Dayton Rims colliervilledave Conversion General Discussions 2 01-11-2008 05:16 PM
rims odee Conversion General Discussions 10 05-03-2007 09:19 PM
Has anyone switched 22.5 rims and tires to 24.5? crazycal Conversion General Discussions 0 02-28-2007 11:42 AM
