Old 02-12-2019, 02:48 PM   #1
MollyCMo's Avatar
What do you think about this skylight?
Any thoughts on this skylight? It's not expensive so I'm concerned it's not a good choice...
https://www.amazon.com/ICON-01859-RV...125159919&th=1
MollyCMo is offline   Reply With Quote
Old 02-12-2019, 03:11 PM   #2
Chassis: IH
It looks to be designed for a flat roof, not a curved one. Will that be an issue for you?
Old 02-12-2019, 04:02 PM   #3
There's not much curve at the top of the roof, I'm sure that skylight will flex enough to seal with Butyl tape and sealer. That doesn't look like a bad deal as skylights go. Would like to know what material it is?
Old 02-14-2019, 09:29 PM   #4
david.dgeorge07's Avatar
Chassis: Thomas
Engine: CAT 3126
Which way would you orient it. Aren’t the ribs on like 28” centers? If you put the long dimension of it perpendicular to the direction of travel I think you might have some problems with curvature of the roof.
My Build Thread:
https://www.skoolie.net/forums/f11/4-...ner-18205.html
Old 02-15-2019, 12:39 PM   #5
MollyCMo's Avatar
I'm glad you asked - I was thinking this might work in the center, maybe I could weld a frame with flanges that extend up a bit more on the ends to compensate for the lack of curve...I'm an amateur welder tho so concerned about making it air/water tight...
Old 02-15-2019, 12:47 PM   #6
MollyCMo's Avatar
Oh cool. I've never heard of Butyl tape so I just googled it and came across this article. Do you think Acrylic tape might be better based on this info? Looks like the tricky part would be getting it to set at the correct "bend" since acrylic tape takes so long to set.
Old 02-15-2019, 12:53 PM   #7
MollyCMo's Avatar
That is a GREAT question and I'd love to know the answer. I don't have a bus yet, and figuring out dimensions is the hardest part of the pre-planning. Do you know for certain that the ribs are 28" apart? I'm guessing like everything else it might vary between makes/models? I've been looking at photos online and trying to guesstimate...but obviously I can't do any really planning with just assumptions
Old 02-15-2019, 12:55 PM   #8
MollyCMo's Avatar
Oh yeah, forget to mention, it's polycarbonate. Which as I understand, would be better than acrylic for trying to bend it a bit?
Old 02-15-2019, 02:21 PM   #9
geminusprime's Avatar
Chassis: Vista 3600
Engine: DT466E / AT545
It likely will flex, however due to the geometry it still won't be a great fit. While the lateral edges bend to conform to the slight bend, the medial edges will bend "up" and away from the roof.
This is because it's not a flat surface (ie a sheet of flexible transparent ploy) but rather has a bit of depth.
It's possible since the roof curve isn't great, but would put constant stress on the poly which may lead to cracks forming down the road (quite literally).
geminusprime is offline   Reply With Quote
Old 02-15-2019, 02:27 PM   #10
Polycarbonate (Lexan) is superior due to the fact it won't crack or break, like plexiglas or acrylic sheet does. We use it as racer windscreens because almost nothing can penetrate it. I think if you use a strong method to secure it (rivets or screws)there should be no edge curl. The use of thick butyl tape helps fill any discrepancy in the curve.
Old 02-15-2019, 03:47 PM   #11
Chassis: Thomas
Engine: CAT 3126
You can find info in my build thread, but I just used flat sheets of thin lexan. It worked well and the sheets are strong enough to stand on, but thin enough to curve to the contour of the roof. I have a row of 4.
My Build Thread:
Old 01-30-2024, 05:30 PM   #12
Curious about heat build up inside the bus... what has been your experience? How have you solved any of the problems? Still happy with your skylight install? What if anything would you change?
mgnmpi is offline   Reply With Quote
