Old 02-05-2016, 11:32 AM   #1
jacobszall's Avatar
Chassis: Chevy Blue Bird Mini Bird (P30)
Engine: GM Diesel 6.2
Question What engine and transmission do I use?
Hello, Skoolies
I own a 2003 All American Blue Bird and I love it so far. I bought it for only a few hundred dollars, but it needs a bit of work. In this project, I have three major phases: get it to run, gut it, build in it. I'm almost done getting to to run and almost done gutting it, too! The biggest part to get my bus driving again is a transmission. There, currently, is no transmission in the bus and I'm not sure what transmission I can use. From what I can tell, my bus is from the A3 series. It is also rear engine.
I've been told it's either an Allision MT643 or an Allison545. I was also told it has a DT466E engine.. but both of these suggestions are from Reddit. I'm hoping to get more of a solid answer from the Skoolie forums.
Thank you.
jacobszall is offline   Reply With Quote
Old 02-05-2016, 12:20 PM   #2
Chassis: E-450
Engine: 7.3 Turbo
These might help you out:
Service Manual for Blue Bird All American
What is the basis of the engine guess? Do you have pictures of it that you could share?
PigPen is offline   Reply With Quote
Old 02-05-2016, 12:31 PM   #3
jacobszall's Avatar
I've been looking at the manual and haven't found too much information yet. Nothing that tells me when I need. My bus doesn't have a transmission at all, haha. I'm heading over to my bus now and I'll take a picture of the engine.
Old 02-05-2016, 12:58 PM   #4
crazycal's Avatar
An Blue Bird All American is the Cadillac of buses. Cummins engine and probably a MD3060 but maybe a MT643.
I'm hungry!
You Gotta Let Me Fly
Old 02-05-2016, 01:36 PM   #5
jacobszall's Avatar
The engine says ISC Cummins on it. Not sure what kind, though.
I need to buy a transmission kind of soon, would you put betting money on the MT643 or the MD3060?
Edit: did some more research, I believe the engine I have is the Cummins 8.3
Old 02-05-2016, 02:15 PM   #6
You can always take the VIN and contact the mfr and ask for the build sheet. No guarantees if they'll pay any attention to you, but some do and t's the Rosetta Stone for your bus; it says make and model of each little tidbit that went into it.
Old 02-05-2016, 03:56 PM   #7
Very sweet engine, but you need to know for sure what the bolt pattern is on the bellhousing or adapter. Probably an SAE3 but could be a two. It will go a lot smoother if you don't have to get/make an adapter to mount the tranny.
Check online for SAE transmission bolt patterns or have a mechanic check it before you invest to see what will fit and what will be involved. Some adapters are cheap, others outrageous and some trannies will bolt right up.
Good luck with it.
Old 02-05-2016, 08:37 PM   #8
charles_m's Avatar
Year: 1982
Chassis: International S1800
Engine: DT466 Trans: MT643
Id bet my arse it had an MD3060--does it still have the shift selector in the dash?
If it does and its a push button one, then you know it was an electronic trans and most likely a 3060.
All the all americans I know of after the mid 90s came with the MD3060s
Thats probably the best engine and trans combo available in a school bus!
www.bustoshow.org
Blog: www.lookatthatbus.com
Instragram: @lookatthatbus
Old 02-05-2016, 10:46 PM   #9
jacobszall's Avatar
Awesome! Thanks! Yeah, it has a the push button reverse/drive selection thing. Awesome!!
Old 02-05-2016, 11:38 PM   #10
Coachwork: IC
Chassis: CE300
Rated Cap: 32
Let me know if you find any deals on 3060's.
I'm thinking of upgrading.
