Old 04-01-2016, 07:54 PM   #1
Coachwork: International Thomas
Rated Cap: 71
What is an "in frame" and what does it entail?
Hello!
I was talking to a person about buying buses, and they were talking about how "in frames" should be done around 200k miles. I asked him what that was, and he told me it meant overhauling the engine. I did not want to ask what that was, so I'm asking all you wonderful mechanically inclined peeps. So what do they do to a bus that gets an over haul? Any idea for the cost of something like that?
Thanks
Virginia
HealthyPetsBus is offline   Reply With Quote
Old 04-01-2016, 08:12 PM   #2
Docsgsxr's Avatar
Engine: Cat 3126b 250 HP
Rated Cap: Only 1 seat
It means to rebuild the head, cylinder sleeves, rings, injectors and seals with the motor still in the bus. A complete rebuild involves pulling the motor, replacing the crank, pistons, wrist pins etc.
My build thread - viewtopic.php?f=9&t=467197
Old 04-01-2016, 08:24 PM   #3
crazycal's Avatar
Some engines are a wet sleeve design meaning the have cylinder liners that can be removed and replaced with new ones that have new pistons in them. This can be done while still in the truck or bus, in frame. A 5.9 Cummins engine has to be pulled out, disassembled, sent to the machine shop to be bored out for new pistons.
This is what an in-frame kit looks like.
International Navistar DT466E Inframe-Overhaul Engine Rebuild Kit
I'm hungry!
You Gotta Let Me Fly
Old 04-01-2016, 08:30 PM   #4
Docsgsxr's Avatar
Good call CC. I just took for granted and thought about my Cat motor. I didn't even think about those without sleeves.
Old 04-01-2016, 08:38 PM   #5
Pretty sure the Cummins 5.9 is a wet sleeve design, making it eligible for in frame rebuilds.
DT Rutledge is offline   Reply With Quote
Old 04-01-2016, 08:49 PM   #6
crazycal's Avatar
Pretty sure its not. Prove me wrong and I will eat my shoe...oh wait, they kind of stink something fierce.
I'm hungry!
Old 04-01-2016, 09:11 PM   #7
Why would they sell these, then? https://dieselrebuildkits.com/k2/die...ne-rebuild-kit
Old 04-01-2016, 10:00 PM   #8
crazycal's Avatar
Since a bus doesn't have a cross member, I guess you can pull the pan and access the crank and con rods. Maybe if you want to slap in new pistons after honing your cylinders. The kit doesn't say liners. If you damage the cylinder wall, I promise you that you will be pulling that block. So yes, I guess you can do an in frame but that doesn't mean it has liners or sleeves. Here is a list of parts from the kit you linked to. Look at the ISX kit, it lists liners.
includes:
6 x Piston Crown
6 x Piston Skirt
6 x Piston Ring-Sets
6 x Piston Pins & Retainers
1 x Head Gasket Set
1 x Main Bearing Set (Std.)
1 x Rod Bearing Set (Std.)
1 x Thrust Washer Set
1 x Set of Injector O-Rings
1 x Rocker Cover Gasket
1 x Oil Pan Gasket
I'm hungry!
Old 04-01-2016, 10:40 PM   #9
Well crap. I did some online research. 6bt's are not sleeved. My appologies.
Old 04-02-2016, 12:19 AM   #10
It is not. That's one of the reasons why some of us prefer the DT's.
Roll Your Own Build Thread
