Old 07-26-2017, 10:38 AM   #1
Engine: DT 466
Rated Cap: 44
What is it ?
what might this be
pwalker is offline   Reply With Quote
Old 07-26-2017, 10:44 AM   #2
Rust?
Iheartbus is offline   Reply With Quote
Old 07-26-2017, 12:14 PM   #3
Engine: DT 466
Rated Cap: 44
this is located passenger side lower part of the engine
Old 07-26-2017, 12:40 PM   #4
Traveling
Engine: 5.9L Cummins
Rated Cap: '00
old bus?
looks like old voltage regulator to me, just a guess. Primitive relay? Any wires? Any noise from it?
Old 07-26-2017, 01:01 PM   #5
Engine: DT 466
Rated Cap: 44
it's on a 1998 International DT466E Thomas
No wires that I can see no noise
Looks like it has some kind of fluid in it
Old 07-26-2017, 02:15 PM   #6
Blue fluid would seem like windshield wiper fluid to me
Old 07-26-2017, 08:29 PM   #7
Engine: 466DT
Originally Posted by pwalker View Post
what might this be
Its your water/fuel (diesel) separator. If you look, one line from your tank goes to it, then over to the fuel filter. There should be another return line back to your tank from the fuel filter/pump side, I believe.
Hvbuzz is offline   Reply With Quote
Old 07-26-2017, 10:56 PM   #8
There was a similar thing on John Deere tractors, may be the same. Fuel filter / water separator .
Steven UK is offline   Reply With Quote
Old 07-27-2017, 12:48 PM   #9
Engine: DT 466
Rated Cap: 44
That makes sense to me. Thanks for you inputs. This stuff is all new to me but I'm learning, I guess that's what counts.
It runs fine so i guess i should just leave it alone till there is a reason to mess with it? Any thoughts
Old 07-30-2017, 12:16 AM   #10
bus-bro's Avatar
Engine: 3208 na boat anchor
Change all fuel filters, and I would say that thing included. At the very least, it's damaged. It's best to know how to change fuel filters on a diesel before you do it. Things like getting air (or debris) into fuel lines and subsequent excessive cranking of the engine has caused much grief to those learning how to maintain diesel engines.
