07-24-2013, 01:13 PM
Chassis: Saf-t-liner
Engine: Cat 3126 - MD 3060
What is this?
I know it goes to the gas tank, I can tell its never been opened, why would you need it?
07-24-2013, 01:16 PM
Engine: DT466/AT545
Re: What is this?
It enables you to work on the top of the tank without having to drop the tank, which would be a huge hassle. So, for instance, if you had an in-tank fuel pump go bad, or a fuel line break, or ... things like that.
07-24-2013, 01:24 PM
Re: What is this?
I thought that, so when I lay my floor do you think I should leave access to it? That's easy enough, so it would be worth it right?
07-24-2013, 02:05 PM
Engine: DT466/AT545
Re: What is this?
Originally Posted by ThePimentals
...so when I lay my floor do you think I should leave access to it? That's easy enough, so it would be worth it right?
Well, that's what I did. Of course mine is hidden under a couch, so it is not an eyesore, and I couldn't think of any good reason to seal it up.
07-24-2013, 03:53 PM
Rated Cap: 89
Re: What is this?
Our access will be under the dishwasher. We planned it that way. We have already used it to pull and repair the fuel level float. Pulling a dishwasher isn't a big deal.
07-24-2013, 04:18 PM
Re: What is this?
Great, sounds like ill leave the access. Thank y'all!
07-24-2013, 04:21 PM
Year: 94
Coachwork: b/b
Chassis: tc2000
Engine: 5.9
Re: What is this?
no just cover the hole up.and someday youll fine out  why its there gezzzzzzzzzzzzzz
07-25-2013, 12:28 PM
Re: What is this?
hmmmmm,
im about to put a shower on top of mine. also, never been opened.
dang it.... nothing is easy
07-25-2013, 02:30 PM
Year: 94
Coachwork: b/b
Chassis: tc2000
Engine: 5.9
Re: What is this?
so u going to cut a hole in your shower floor when u need to get to the dending unit on the tank.....sound like this boy has brains....
07-25-2013, 04:50 PM
Re: What is this?
nope... i own a bus
so......i'm glad i looked at this thread.
whats in the tank of a diesel?
is it just the sending unit? i could live keeping track of my tank if that fails.
or
is there a fuel pump that maybe i should replace now and be good?
this complicates things
07-25-2013, 05:08 PM
Re: What is this?
worst case would be if one of the rubber fill hoses gets a crack or the vent line gets clogged
some may have lift pumps intank
