Old 04-12-2010, 06:10 PM   #1
Engine: 466
What is this vent.........
and what is it for? There is one in front of the front roof exit,and one at the very rear of the roof. What is it venting,and what kind of problems will it cause when I patch and waterproof it? The roof leaks,and this is an apparent gaping hole.
Any ideas?
Funkpirate is offline   Reply With Quote
Old 04-12-2010, 06:41 PM   #2
Elliot Naess's Avatar
Engine: 5,9 Cummins
Re: What is this vent.........
Without seeing more of your bus, I expect it is simply fresh air for the interior of the bus. I had a small one on Millicent, and I sealed it up.
Front engine buses can have problems with engine fumes getting inside. I solved this by cutting a big hole in the front, where the intake to the heater is. At speed, air blasts in thru the heater system much more effectively than before -- problem solved.
Elliot
Old 04-13-2010, 06:18 AM   #3
Engine: 466
O.K.,they're good as gone.............
Old 04-13-2010, 10:30 AM   #4
Coachwork: 2003 Thomas E-350 shorty
Chassis: E350
Engine: 7.3 Powerstroke
Rated Cap: 24
My vent cover was a bit more domed and only open to the rear; I took the non-functional fan out, made a template and plumbed my black tank vent into it. Used black corrugated tubing for a washing macine drain, or was it sump pump drain tubing... Anyway, that's a good use since it is an existing hole in the roof.
If it isn't grown, it has to be mined
http://weathersticker.wunderground.c...Winnemucca.gif
elkoskoolie is offline   Reply With Quote
Old 04-14-2010, 12:31 AM   #5
Engine: 7.3 diesel
it seems to be only on school buses. If you look at transit buses such as a bluebird transhuttle there is not one there at all. So it can be patched up with no worries. I left mine open as it didn't leak and I figure it gave a spot for the hot air to rise out of.
Old 04-15-2010, 10:46 PM   #6
GoneCamping's Avatar
There is a hollow channel about 2" wide that runs the length of the bus in center of the roof where there is no insulation. This channel and those vents allow the heat to escape out.
Mine had a tendancy to leak when it rained, but since I didn't alter the roof I figured they were important in some way, so I left them. But to control the leakage, I bought some home type vent covers at Lowes and put them over those vents...
*Cliff*
...Your home has brake lights
1994 Jeep Grand Cherokee
Chesapeake, Virginia
GoneCamping is offline   Reply With Quote
help with fridge vent lornaschinske Heating, Cooling and Appliances 5 06-11-2017 11:56 PM
Vent Info rex_1_mn Heating, Cooling and Appliances 2 09-30-2012 08:16 PM
Looking for a used vent. Bus Project Conversion General Discussions 0 02-11-2010 09:25 PM
Fridge Vent! GoneCamping Conversion Tutorials and How-to's 1 09-30-2008 11:04 PM
Vent Info bcschro Skoolie Conversion Projects 4 12-31-1969 07:00 PM
