Old 10-06-2016, 08:21 PM   #1
karrlot's Avatar
Coachwork: Ward
Rated Cap: 65 passenger
What kind of a Webasto do I have?
So I have a Webasto and I'd like to get a manual for it, but I can't figure out what model/type/kind I have. I've cleaned the label up as much as I can but tried not to scrape off the words. Can anyone help me out with figuring out what model this is?
Please check out my blog-
Follow the (lack of) progress on the Karr Family Kamping Bus Blog
Here is my woefully inadequate build thread:
https://www.skoolie.net/forums/f11/i-...bus-12296.html
karrlot is offline   Reply With Quote
Old 10-06-2016, 10:54 PM   #2
AlleyCat67's Avatar
Year: 2005
Engine: Detroit MBE906
The only thing I can find that's even close looks like something that's available only in the UK:
https://www.webasto.com/gb/markets-p...-motorcaravan/
Old 10-07-2016, 07:22 AM   #3
karrlot's Avatar
Coachwork: Ward
I found that UK model too. I'll keep looking. I'm hoping someone on here has a similar one that can tell me the model. Based on one of the labels it looks like it might be from 2005. It's not listed on the line setting ticket, nor can I find a maintenance record about it.
Old 10-07-2016, 08:44 AM   #4
AlleyCat67's Avatar
Year: 2005
Hopefully so..... I zoomed in on the label as much as I could and did a search on what I thought the numbers were on the label, but came up empty.
Old 10-07-2016, 08:47 AM   #5
yeah they werent factory installed..
Like air conditioning, usually the selling Bus dealer would have the busses outfitted with those options after they came off the line.. "Factory approved, factory option, Dealer installed".
have you turned it on? you might try calling webasto and talking to them.. the comany is still in business so you have a shot at getting some info on it.
Old 10-07-2016, 01:12 PM   #6
karrlot's Avatar
Coachwork: Ward
Yes it works fine. I don't have any issues at all. I just would like to have some information on it in case something comes up. I just can't even get the model number off of the label.
Old 10-07-2016, 01:26 PM   #7
im thinking some pictures.. any date-code info you may have.. and then a call to webasto and I'll bet they can match it up , ive had pretty good luck doing that with various parts on the bus thus far..
even Bergstrom heater parts for the bus heaters..
Old 10-07-2016, 04:38 PM   #8
Chassis: Blue Bird
Engine: ISC 8.3
It's a 5.2 kW Thermo Top C. I.. umm.. "digitally enhanced" one of the pictures for you. Mostly it helped that I knew what to look for in the label, but I also leaned on a nice clean picture from eBay, which also happened to have the label in English rather than German, to work out some of the details.
That one on eBay has part number 89073P. I can make out 073 on your label, but overall I think your part number may be 89073N.
I'll leave the extraction of the serial number as an exercise to the reader.
Old 11-07-2016, 12:00 PM   #9
If you can't figure it out, you may have to take it apart to find out. Different models use different components.
Tegra1027 is offline   Reply With Quote
