View Poll Results: What kind of mileage do you get?
3-5 with Gas 11 3.29%
5-7 with Gas 35 10.48%
7-10 with Gas 34 10.18%
10+ with Gas 11 3.29%
3-5 with Diesel 1 0.30%
5-7 with Diesel 21 6.29%
7-10 with Diesel 118 35.33%
10+ with Diesel 103 30.84%
Voters: 334. You may not vote on this poll
Old 11-05-2015, 07:31 AM   #101
Chassis: MVP ER
Originally Posted by porkchopsandwiches View Post
On our 9,000 mile trip this summer, the trip average in my 1999 Thomas bus with 3126b CAT (electronic engine) and 6-speed Allison MD3060 (6th gear enabled), cruising at 65 with foot buried most of the trip, weighing in at about 24,500 lbs, we averaged 8.2 mpg. Best was 9.3 going SE through Yellowstone on 287, worst was on PCH (route 1) at about 6.5 (constant hills and stop-and-go letting people pass).
Edit: 4.62 rear gears turning ~2,100 rpm at 65.
Porkchop,
Did your bus come stock with the 4.62 or did you change the carrier?
ism minerals is offline   Reply With Quote
Old 11-12-2015, 04:35 PM   #102
Chassis: Saf-T-Liner MVP ER
Engine: CAT 3126b Rotella-Chugger
Originally Posted by ism minerals View Post
Porkchop,
I do not know for a fact that it is 4.62 but judging by RPM at 65 and wheel diameter, I calculated it to be 4.62. I did not touch it, it came with it if it is in fact a 4.62.
porkchopsandwiches is offline   Reply With Quote
Old 11-13-2015, 08:55 PM   #103
Rated Cap: 40 Prisoners
By my calculation if you sixth gear is opened up it is .65 ratio overdrive and you have
11X22.5 tires with a diameter of 41.3 inches and your doing 65 miles per hour at
2100 rpm that would make the rear differential ratio 6.2 or there abouts. My bus has
5.38 differential ratio and 43 inch diameter tires 12X22.5 tires running only 5th gear
which is .75 ratio overdrive, at 2000 RPM I am doing 65 MPH.
Old 11-27-2015, 03:57 PM   #104
CaptSquid's Avatar
Chassis: HDX
Engine: Cat C7
Rated Cap: 84 passenger
I averaged 7.5 on a trip from Kanakee, IL to Billings, MT.
Old 02-10-2016, 05:11 PM   #105
Year: 1956
Chassis: Ford B-600
Engine: Ford Big Block FE
1047 miles from Allenton, WI to Charleston, SC. 7.6 MPG.
Toyman01 is offline   Reply With Quote
Old 02-10-2016, 06:26 PM   #106
2kool4skool's Avatar
After almost 5000mi, still at 11.5 mpg. We tow almost always with 2 setups. One is 3200# the other 4500#. Not towing= SAME!
20,000# verified wt, 5.9 185hp w/545. 3:54 ratio and 55-60 mph.
Don, Mary and Spooky the cat.
Old 02-10-2016, 07:18 PM   #107
Coachwork: Gillig
Chassis: 743
Engine: Cummins Diesel
With my Gillig its gallons per mile
tinybelugabus is offline   Reply With Quote
Old 04-04-2016, 09:52 AM   #108
fuel mileage
We want to buy a school bus to make a rv. Looking at two the first one is a 8.2 diesel allison trans. The second one is a 454 chevy 5 speed . Can someone give me an estamat on fuel mileage for both?
joey is offline   Reply With Quote
Old 04-04-2016, 09:55 AM   #109
Numerous other factors. Size of bus...gear ratios for trans & rear end...tire size...normally aspirated or turbocharged...intercooler (diesel only)...
That said...most any diesel will get better mpg than the 454. Anyone else care to chime in here?
Old 04-04-2016, 10:03 AM   #110
FWIW my 454 powered 10,000lb MH got 5-7.
what kind of tank? BootsBus2011 Veggie Oil | WVO | Biodiesel | SVO 3 12-04-2011 10:32 PM
Help! What kind of batteries do I need for my bus? elmoe Electrical, Charging and Solar 5 05-04-2009 12:11 PM
what kind of bus dieselman69 Conversion General Discussions 4 11-15-2008 01:53 PM
1 of a kind 1 of a kind Skoolie Conversion Projects 2 09-09-2007 10:11 PM
Water Injection Milleage Help phillip266 Conversion General Discussions 2 06-23-2005 08:43 AM
