View Poll Results: What kind of mileage do you get?
3-5 with Gas
13 |
2.97% |
5-7 with Gas
40 |
9.13% |
7-10 with Gas
46 |
10.50% |
10+ with Gas
18 |
4.11% |
3-5 with Diesel
2 |
0.46% |
5-7 with Diesel
27 |
6.16% |
7-10 with Diesel
161 |
36.76% |
10+ with Diesel
131 |
29.91% |
11-05-2015, 07:31 AM
#101
Chassis: MVP ER
Originally Posted by porkchopsandwiches
On our 9,000 mile trip this summer, the trip average in my 1999 Thomas bus with 3126b CAT (electronic engine) and 6-speed Allison MD3060 (6th gear enabled), cruising at 65 with foot buried most of the trip, weighing in at about 24,500 lbs, we averaged 8.2 mpg. Best was 9.3 going SE through Yellowstone on 287, worst was on PCH (route 1) at about 6.5 (constant hills and stop-and-go letting people pass).
Edit: 4.62 rear gears turning ~2,100 rpm at 65.
Porkchop,
Did your bus come stock with the 4.62 or did you change the carrier?
11-12-2015, 04:35 PM
#102
Chassis: Saf-T-Liner MVP ER
Engine: CAT 3126b Rotella-Chugger
Originally Posted by ism minerals
Porkchop,
I do not know for a fact that it is 4.62 but judging by RPM at 65 and wheel diameter, I calculated it to be 4.62. I did not touch it, it came with it if it is in fact a 4.62.
11-13-2015, 08:55 PM
#103
Rated Cap: 40 Prisoners
By my calculation if you sixth gear is opened up it is .65 ratio overdrive and you have
11X22.5 tires with a diameter of 41.3 inches and your doing 65 miles per hour at
2100 rpm that would make the rear differential ratio 6.2 or there abouts. My bus has
5.38 differential ratio and 43 inch diameter tires 12X22.5 tires running only 5th gear
which is .75 ratio overdrive, at 2000 RPM I am doing 65 MPH.
11-27-2015, 03:57 PM
#104
Chassis: HDX
Engine: Cat C7
Rated Cap: 84 passenger
I averaged 7.5 on a trip from Kanakee, IL to Billings, MT.
02-10-2016, 05:11 PM
#105
Year: 1956
Chassis: Ford B-600
Engine: Ford Big Block FE
1047 miles from Allenton, WI to Charleston, SC. 7.6 MPG.
02-10-2016, 06:26 PM
#106
After almost 5000mi, still at 11.5 mpg. We tow almost always with 2 setups. One is 3200# the other 4500#. Not towing= SAME!
20,000# verified wt, 5.9 185hp w/545. 3:54 ratio and 55-60 mph.
Don, Mary and Spooky the cat.
02-10-2016, 07:18 PM
#107
Coachwork: Gillig
Chassis: 743
Engine: Cummins Diesel
With my Gillig its gallons per mile
04-04-2016, 09:52 AM
#108
fuel mileage
We want to buy a school bus to make a rv. Looking at two the first one is a 8.2 diesel allison trans. The second one is a 454 chevy 5 speed . Can someone give me an estamat on fuel mileage for both?
04-04-2016, 09:55 AM
#109
Numerous other factors. Size of bus...gear ratios for trans & rear end...tire size...normally aspirated or turbocharged...intercooler (diesel only)...
That said...most any diesel will get better mpg than the 454. Anyone else care to chime in here?
04-04-2016, 10:03 AM
#110
FWIW my 454 powered 10,000lb MH got 5-7.
04-04-2016, 12:38 PM
#111
what transmission auto or standard?
04-04-2016, 02:33 PM
#112
my last bus was a shortie blue bird with a 454 Chevy in it that I did some work on to make it nice N fresh.. cammed with an RV cam and it got 5-6 on average.. I dont know the exact transmission... 545 maybe? it was a 4 speed auto
04-04-2016, 02:37 PM
#113
5 speed standard
04-04-2016, 02:52 PM
#114
I'd hold out for a better drivetrain than gas or the fuel pincher.
04-04-2016, 02:56 PM
#115
th400....,
05-22-2016, 11:05 PM
#116
Chassis: Chevy P30
Engine: Chevy 6.2L Diesel
Normally I get ~13-15 mpg, although I'm having a transmission problem with a shift solenoid that's keeping me out of overdrive, so it's 7-8 at the moment.
08-04-2016, 06:34 PM
#117
I recently purchased a 92 ford b600 bluebird 52 passenger bus. It also has the 6.6 inline diesel in it. I get from 10- 15 mpg with it. Its also a 10 speed manual transmission so maybe that has something to do with it.
01-19-2017, 02:00 AM
#118
Engine: Caterpillar 3116
Rated Cap: 78?
Around ten mpg with the old Bluebird, 6.6L Caterpillar 3116, auto, empty tanks on the road. Around 65 on the flats, not too shaby.
02-23-2017, 10:08 PM
#119
Year: 1982
Chassis: GMC B6000
Engine: 350 on Propane
Rated Cap: 24
Not an option on the poll: 5-6 on Propane
24 Passenger, 350 with manual 5 speed
02-23-2017, 10:47 PM
#120
Chassis: TC 2000 bluebird
Engine: 5.9 cummins
I have a 1998 Bluebird 34' tc2000 with a 6bt 5.9 cummins. I got 9.98mpg driving it from Baltimore Maryland to Saginaw Mi before the conversion.
We will see what it gats after.
Bill
Michigan
