Old 09-17-2015, 01:00 PM   #21
Chassis: International 3800 AmTran (wish it was a TransAm)
Smile
Originally Posted by Snurbalurb View Post
Hey I'm doing the same thing, do you have to remove the white panel below which has the lip? Or just leave that lip there and frame around?
On top of that apparently being part of the overall structural integrity (see post above) I think you will probably want that lip to help secure furniture and other things. It is perfect for it. It even has pre-drilled holes for you (where the seats were!)
Either way, the metal panels on mine didn't go below that. As long as I unscrewed/grinded off the screws at the bottom, they end right above that chair rail.
AlbatrossCafe is offline   Reply With Quote
Old 09-17-2015, 04:20 PM   #22
Scooternj's Avatar
Chassis: International 3000RE
Engine: T444E/AT545
Rated Cap: 75
For the love of all that's unholy in R'lyeh, leave the chair rail in place. It's the single most important structural piece that holds a bus together.
Captain Obvious on deviantArt
Old 09-17-2015, 08:21 PM   #23
Thanks guys, I just now need to figure out how to frame around it, I just pulled the ceiling and insulation. You guys know of a thread to find out how to frame around the rail? It's my first bus, my first wood working project, first electrical and first anything about a bus/rv
Snurbalurb is offline   Reply With Quote
Old 09-17-2015, 08:38 PM   #24
Engine: 190hp 5.9 Cummins
If you strap the entire interior with 2x4's running horizontally like I did, you get a perfect thermal break, a place to screw the interior to, and it bridges over the chair rail.
It also makes space to run wires, plumbing, ect.
That's how Jasty did his.
http://www.skoolie.net/forums/f27/ar...rust-8870.html
And I did mine.
http://www.skoolie.net/forums/f11/th...ime-10138.html
And there are 4 or 5 others that did as well.
IMO it's the best way to do a interior. I would not think of doing it any other way.
Using 3/4 plywood strips doubled up works better than 2x4's. Unlike the 2x4, the plywood will not warp, pull loose, split, ect.
Old 09-17-2015, 09:13 PM   #25
And I did mine.
Nice, exactly what I needed to know, appreciate that natster
Old 09-17-2015, 09:19 PM   #26
You bet, glad I could help.
build, interior, international, panels, removal
