Old 10-06-2010, 10:36 PM   #1
Diesel Dan's Avatar
Engine: DT466/AT545
Re: What should I use for heat?
I would go with this stuff:
http://www.homedepot.com/Building-Mater ... ogId=10053
Not sure if it has a foil radiant barrier layer, but there are other similar products that do.
Gallery:
Conversion Thread:
viewtopic.php?t=4959
Old 10-07-2010, 12:00 PM   #2
Locutus's Avatar
Chassis: Super Coach II, 36 Ft. RE
Engine: Cat 3208T, MT643
If you will have at least a 30 amp AC service, perhaps you could go with electric heat. Two or three of these might do the trick:
http://www.walmart.com/ip/World-Marketi ... r/13141908
I use one of these to keep the interior of my RV from freezing in the winter. I just set it to the lowest power setting. An oil filled space heater is probably safer than one with an exposed coil. Price is right, too.
Locutus
(Latin) loquor loqui locutus dep. [to speak (in conversation); to tell , say, declare, talk of].
Children drink kOOlaid, adults drink T.E.A.
Gallery: http://www.skoolie.net/gallery/v/Skooli ... +Coach+II/
Locutus is offline   Reply With Quote
Old 10-10-2010, 07:54 PM   #3
lornaschinske's Avatar
Rated Cap: 89
It depends. We have pretty good insulation in the walls & ceiling of our BlueBird bus but others here have posted they don't have any insulation or it's not very good. Ours is a thick heavy dense insulation... more like what used to be used on ranges and ovens. I know that we have a cool ceiling in the summer heat. It's so good that we don't plan on adding more insulation to the ceiling (but will add to the walls for thermal break and under the floor as there is none there).
Fulltime since 2006
portable a/c - heat leadsled01 Conversion Tutorials and How-to's 3 01-25-2015 05:20 PM
heat vanpeoplx2 Heating, Cooling and Appliances 10 01-14-2011 07:34 AM
no heat mfrederick Skoolie Conversion Projects 6 01-11-2010 09:05 PM
HEAT phillbus914 Heating, Cooling and Appliances 27 03-07-2008 12:38 AM
I need heat! the_experience03 Conversion General Discussions 8 02-18-2006 08:28 AM
