Old 11-13-2012, 12:11 PM   #1
what the hell is this part???????????
So I was under bus measuring the gas tank and saw this above the filler neck just hanging out
It has 2 wires going into it they ride in the angle iron above hose and kinda looks like it would go around something as a sensor
Sorry for blurry picture
Any ideas???
Old 11-13-2012, 01:10 PM   #2
GreyEagle's Avatar
Re: what the hell is this part???????????
Sure looks like the "Self Destruct Lever" for a 1997 Crown bus.....
The 2 wires provide the electricity to ignite the fuel in the tank should you feel the need or get so feed up it comes down to it......
Whatever you do "DO NOT PULL" it while you're close by, Set the timer and haul ass........ the lever will fall in appx 15-20 minutes after set the timer depending on how many beers you have before you get the feeling to pull such a thing. Whatever you do be sure to park away from any homes, houses, barns or buildings as the flames from the explosion will burn anything within a 50 ft radius of the bus. Remember to stop and detour all traffic........ The SRK "(Skoolie Repair Kit'") does not cover any damages from the use of the SDL (Self Destruct Lever)...... You're on your own......
P.S. I got no frigging ideal what it's for.....
GreyEagle
Roll - On...
GreyEagle is offline   Reply With Quote
Old 11-13-2012, 02:13 PM   #3
mmmmmmmm......thanks
now I will have to get a neighbors kid to pull it while I sit back and watch......or I reckon I could tie it to a cow's TAIL..nevermind it's too stupid of an animal to move on it's own
Old 11-13-2012, 07:33 PM   #4
kimberlink's Avatar
Engine: DT466 / AT545
Rated Cap: 71
Bansil, I have a 97 Crown / Cartpenter I can look and see if I have one of those whatyamacallits. where abouts was it located my fuel tank is located on the right side just behind the old school bus door is yours at the same place? Update sorry I don't have anything that looks like that around the fuel tank. there was a round entry light that had two wire going to it near the old door.
The most terrifying words in the English language are: I'm from the government and I'm here to help.
Ronald Reagan
https://s1253.beta.photobucket.com/us...k1961/library/
kimberlink is offline   Reply With Quote
Old 11-13-2012, 09:26 PM   #5
Grey eagle is probably right but I think I saw that same picture in the National Geographic (or was it Mad Magazine) back in 1956 just after the Andrea Dora sank--I'm not sure though.
Old 11-14-2012, 04:05 AM   #6
That does look like a "salvage" picture
Kimberlink,my fuel tank is behing rear wheels in center of frame rails protected by a huge steel "rollcage" you'd think it was an explosive fuel
Old 11-14-2012, 12:50 PM   #7
browncrown's Avatar
Rated Cap: 79 at Birth
I think it is a beer can holder for when you are working under the bus.
BC
My Conversion Thread: https://www.skoolie.net/forum/viewtopic.php?f=9&t=3065
Old 11-14-2012, 02:25 PM   #8
mmmm...insert can .....lay back and pop the lid
I will post results
Old 11-14-2012, 04:06 PM   #9
GreyEagle's Avatar
That sure sounds a lot better than the Self Destruct Lever............ Cheers!!!!
But we still have no ideal what the hell it's for or what it is......... Be careful with it and don't pull too hard........ just in case...
GreyEagle
Roll - On...
Old 11-14-2012, 06:09 PM   #10
lornaschinske's Avatar
Rated Cap: 89
"I don't know what it is, but it's the best looking one I've ever seen!"
Actual quote by one of the antique "experts" on the UK version of PBS's Antiques Roadshow. We thought it was so funny, we look for opportunities to say it.
Fulltime since 2006
Old 11-14-2012, 07:28 PM   #11
I will have to trace it back now...just have to lengthen my "wire" tracer since the bus is 3X longerthan anything else I've had to chase
And I will post results....good or bad
Old 11-14-2012, 09:10 PM   #12
Moderator
crazycal's Avatar
Engine: DT408, AT545
Rated Cap: 23 500 gvw
Kinda hard to get a straight answer around here with all the comedians. Looks like a bottle opener to me.
I'm hungry!
You Gotta Let Me Fly
Old 11-14-2012, 09:22 PM   #13
CC! You should talk!
Old 11-15-2012, 04:01 AM   #14
CC why would one need a powered or heated gatorade bottle opener one a short leash above the fuel inlet tube?
.well come t think of it...it does have a 75 gallon tank
Might get thirsty on a hot day filling up!!
Old 11-15-2012, 08:47 AM   #15
GreyEagle's Avatar
bansil......... did you really have to ask??????????
GreyEagle
Roll - On...
Old 11-15-2012, 10:52 AM   #16
Moderator
crazycal's Avatar
Because sometimes its freezing.
I'm hungry!
Old 11-18-2012, 10:20 AM   #17
kimberlink's Avatar
Rated Cap: 71
Bansil, update I crawl all around underneith my bus looking for something that looked like the part in your picture. I didn't find anything that even came close.... However my bus is on an international chassis with a DT-466. its wasn't made by MI-6 when Q was in-charge so 007 did not drive mine. It could be the old ejection seat lever....
Ronald Reagan
Old 11-18-2012, 04:18 PM   #18
Mmmm....I had a beer(already ingested) and pulled it a little.....no cat was launch(Gizmo)...but I didn't have it ruuning either...
Old 11-18-2012, 08:28 PM   #19
Being a Lucas Electric guy at heart, I'd by now just have cut the wires, spliced them together with masking tape, started her up and followed the smoke--at least I'd have a clue which way to look next. And, once you burn the wires up you really don't need the question answered anyway--so go for it--we'll all be waiting to see the pics!
what is this part? bansil Conversion General Discussions 2 01-16-2012 11:50 AM
The rest of them... Part 4 SpongeBob Skoolie Conversion Projects 1 02-28-2010 04:29 PM
The rest of them... Part 6 SpongeBob Skoolie Conversion Projects 1 02-28-2010 02:58 PM
The rest of them... Part 5 SpongeBob Skoolie Conversion Projects 0 02-28-2010 02:42 PM
Road trip from hell... Russell Everything Else | General Skoolie Discussions 1 09-13-2009 01:34 PM
