Old 09-30-2018, 09:23 AM   #1
Coachwork: Thomas Vista
Engine: 7.3 L
what to do with extra length of heater hose from rear heat?
what are my options for the 5-6' of heater hoses from the rear heater.
the heater has been removed and a elbow installed looping it back to just recirculate the flow. can I shorten these hoses to get them out of the way of my build. w/o any issues throughout the rest of the system? Ive read a few different conflicting ways to deal w/ this.
thank you for any input.
SKOOLINAROUND is offline   Reply With Quote
Old 09-30-2018, 09:43 AM   #2
Chassis: Amtran
Yes you can cut them back to the heater before it or all the way back to the front as long as you loop it and it maintains the same direction of flow. I took all of mine out to the step heater and everything works great!
Cdimples67 is offline   Reply With Quote
Old 09-30-2018, 10:16 AM   #3
Engine: 7.3 L
thanks I shall do just that
Old 09-30-2018, 06:26 PM   #4
Marceps's Avatar
Chassis: Saf-T-Liner MVP ER
Engine: CAT 3126
No shut-off/redirect valve?
That tubing is good stuff, by the way.
Marceps is offline   Reply With Quote
Old 09-30-2018, 07:58 PM   #5
mikeypj's Avatar
Engine: 9.L
Rated Cap: 64
Im using mine to replace the hoses i had to cut to get the drivers side behemoth heater out. Going to run it from the point where it connects to the 2" heater hose under the hood..
mikeypj is offline   Reply With Quote
xtra heater hose???
