Old 12-16-2017, 10:52 AM   #21
Year: 2006
Chassis: IC bus
Engine: VT365
Rated Cap: 35C24A
Well, it is done.
There are a lot of lights to access and cables to leave space for within the spray foam. Keeping that access with the spray foam is going to take some creativity. Thinking of glueing some short lengths of 4" PVC pipe around the lights to stop the foam from expanding into those areas.
Tyania is offline   Reply With Quote
Old 12-16-2017, 12:18 PM   #22
Chassis: Saf-T-Liner MVP ER
If you do that you can later cut "plugs" from foamboard to fill the spaces.
Steve Bracken
Build Thread
Old 12-16-2017, 01:05 PM   #23
Robin97396's Avatar
My wiring and lights are all foamed in place semi-permanently. It's easy enough to pick away at the foam to gain access.
I had let my back wall panels remain for about six months longer than the other interior panels. They were somehow attached to the floor. Finally I torqued them out with a prybar. Procrastination didn't work well for me.
Robin
Nobody's Business
Old 12-16-2017, 09:01 PM   #24
Year: 2006
Chassis: IC bus
Engine: VT365
Rated Cap: 35C24A
I like it...
Old 12-16-2017, 09:05 PM   #25
Year: 2006
Chassis: IC bus
Engine: VT365
Rated Cap: 35C24A
Thankfully mine were not.
